HS Insteon vs. Sandler Insteon Plugin
    #16
    are you running hs3 or hs4?
    to find it in hs3, the plugins/manage page , and look under the Additional Interfaces
    i do not think i have my plugin listed on hs4
    Mark
    HS3 Pro 4.2.19.5
      #17
      Im running HS4 will that work?
        #18
        i dont my have my hs3 insteon plugin published for HS4. there are a few UI issues people are reporting.
        Mark
        HS3 Pro 4.2.19.5
          #19
          Thanks for the info. In the future are you planning to update the plug-in for HS4 and can I wait for it or should I pick another product
            #20
            Hs4
              #21
              I'm working on my hs4 insteon plugin. planning on having something working around nov/dec
              Mark
              HS3 Pro 4.2.19.5
                #22
                Hi Mark will your new insteon plugin control EZFlora sprinkler devices as well as lights?Will this plugin run on the upcoming HomeSeer HomeTroller Plus Smart Home Hub or pro model?
                  #23
                  i do not plan to support the ezflora sprinkler devices. I thought someone else already had a plugin for it. not sure about the new hw. I assume my plugin will if it runs homeseer or homeseer pro. my plugin runs on windows and linux. But this is probably a question for HST.
                  Mark
                  HS3 Pro 4.2.19.5
