Mark. I am back with repeated problems from my 2413U running HS2. Intermittently HS can't find the com port and I lose control functions. We have been down this road and it's not reliable. I reboot and pull out the USB and ac connections and get it back. Should I try a new PLM? Thanks. George
Plm USB troubles
This topic is closed.
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb
HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
HSTouch on Intel tabletop tablets (Jogglers) - Asus AIO - Windows 11X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Alexa, Cheaper RFID, W800 and Home Assistant
Nope its there.
Go to Control Panel then click on System. A box will come up called System Properties.
Click on the Hardware Tab. First button on the Hardware Tab is Device Manager.- Pete
You are welcome George.
Here I do not utilize any power savings features on the Homeseer box except for the computer monitor stuff.
That and the computer is running connected to a KVM and I never look at the monitor always accessing it remotely on the network.
Using the Zee for example and it being "solid state" there are really no moving parts in it except the the little traveling electrons. Its regular state is very low powered such that you do not need really any sort of power management.
mcsSprinklers here is also running on a "solid state" device using a CF card / SSD USB stick and doesn't really get warm these days.- Pete
still not right....
ok, after a week or two of resetting the USB device page as noted, i still have problems. same thing, HS Cannot open COM10.... i have to unplug the plm and usb, then re-plug and restart HS, then communications is established. i need my insteon to be more reliable than this... especially with leak detctors etc. any other suggestions welcome. thanksHS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
Originally posted by gfs View Postok, after a week or two of resetting the USB device page as noted, i still have problems. same thing, HS Cannot open COM10.... i have to unplug the plm and usb, then re-plug and restart HS, then communications is established. i need my insteon to be more reliable than this... especially with leak detctors etc. any other suggestions welcome. thanksMark
HS3 Pro 4.2.19.5
Originally posted by gfs View PostCan you give me a quick tutorial on that. It seems to automatically find it. I go thru a USB hub then to HS
Thanks Mark
you may need to run the ftdi clean utility to remove unused com port driver setups that are holding lower ports in use.Mark
HS3 Pro 4.2.19.5
i am working off a usb hub. there are two other devices in it.
details on ports 9 and 10 in device manager seem similar
FTDIBUS\VID_0403+PID_6001+A501LC8IA\0000 com 10
FTDIBUS\VID_0403+PID_6001+A100FXZ5A\0000 com 9
both are FTDI 7-12-13 v 2.8.30.0
not sure how i delete and reassignHS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
the hub does not assign com ports, windows does. you need to look at device manager and see if there are unused com ports you can reassign the plm to or look into the ftdi clean utility I mentioned (ftdichip.com)Mark
HS3 Pro 4.2.19.5
