Mark, I am working on putting some of my Insteon devices in HSTouch using designer and having some issues and wondered if you could help.
I am trying to dim a Insteon Dual-Band SwitchLinc Dimmer device. The device dims just fine using the normal HS3 web application. Also, if I use a standard on/off button in Designer and link to the same Insteon switch, I cannot turn it off or on. What is even stranger, if I control the light locally at the switch or using the web browser, HSTouch does update the slider. For whatever reason HSTouch will not allow me to control any Insteon device.
I decided to sit down and check out a few of my on/off (no- dimming) Insteon switches. These do not work either. The status tracks in HSTouch when the switches are turned on/off locally or via the web browser. However HSTouch is not able to control them. I also have a few Z-wave devices on/off and these work fine in HSTouch.
I have a few Z-wave dimmable devices and these also work fine in HSTouch, status tracks fine and they are able to be controlled using HSTouch.
Any ideas? Should I send some screen shots of the devices? I looked at the devices and there are some obvious differences on the Status Graphics tab between Insteon and Z-wave device, but nothing that should be causing the devices to not be controlled via HSTouch.
I am using the following versions.
HomeSeer: HS3 Pro Edition 3.0.0.96 (Windows)
HSTouch Server: 3.0.0.42
Designer: 3.0.8
Insteon Plugin: 3.0.4.8
I saw a bug that seemed related and have posted some comments, it is Bug 1091, see http://homeseer.com/bugzilla/show_bug.cgi?id=1091
Thanks for any help
Billy
Designer: 3.0.8
Thanks for any help
Billy
