HSTouch Sliders and On/Off not working with Insteon Devices
Guys,
i posted 3.0.5.1 at the following which should fix the hstouch slider issue once you install, add recreatedevices=true to the [config] section of the insteon.ini, and start hs again.
http://forums.homeseer.com/showthread.php?p=1128554Mark
HS3 Pro 4.2.19.5
http://forums.homeseer.com/showthread.php?p=1128554Billy
Originally posted by bdraper View PostThanks Mark, I have downloaded the update and applied it. My initial test works. Very nice job. Thanks. I will continue testing and let you know more tomorrow.
Side note: as for the order of the on, off, slider controls...i'm willing to do the same to change the order to Off, On, slider to make them match zwave, etc. Not sure how everyone else will respond. I was considering another ini setting to allow the user to choose the order. thoughts?Mark
HS3 Pro 4.2.19.5
Mark, I tested quite a while last night, different dimmers, different on/off switches. After installing 3.0.5.1 or your Insteon plugin and setting the flag, everything seems great between Insteon and HSTouch. Thanks so much for your help, it is certainly appreciated. I was reviewing bugzilla and found a different bug that describes the issues I was having and he listed Insteon and HSTouch, it is bug 2127. See http://homeseer.com/bugzilla/show_bug.cgi?id=2127. I am going to see if Joe will test this version of the Insteon plugin and see if it solves his issues as well. I would just like another set of eyes on it.
As for the order of the buttons, not really a worry, being a DBA I notice stuff like that, it can be a curse. As for options, I always like options. I looked at all of my devices, I have Insteon and some Z-Wave. I also looked at the buttons created with the sample plugin. I listed some of the orders I noticed below.
Order of Control Buttons on Device Management Screen
Insteon (on/off) -[On] [Off]
Z-wave (on/off) -[Off] [On]
Insteon (dimmer) -[On] [Off] [slider]
Z-wave (dimmer) -[Off] [On] [On Last Level], slider on the second row
One button in the sample plugin had [Off] [On] [On Last Level] [Speak Hello], slider on the second rowBilly
