Converting from HS2 to HS3
This topic is closed.
    Can I import my Insteon configuration from HS2 into HS3? I have over 70 devices and if I have to reprogram everything it will take forever.
    Jason
    Yes just copy the insteon.ini file to the same place in the hs3 structure, enable the plugin and the devices will be created.
    You must recreate events and triggers however
    Mark
    HS3 Pro 4.2.19.5
      Great - thanks
      How about if I'm also moving to a network PLM?
      Jason
        Originally posted by jrhubott View Post
        Great - thanks
        Jason
        the plugin will recreate the devices regardless of the interface (plm, hub, etc)
        the plugin will not read any information from the hub that you might have created using the smarthome app.
        Mark
        HS3 Pro 4.2.19.5
