I had device polling enabled (At statup) for several devices using plugin version 3.0.4.10 which generates device change callbacks sent to subscribers such as HSTouch. The reason for what's changed is "Status_Support, Dev_Type_String, DeviceType (see screenshot)" and one callback is generated per device that is polled.
The side effect for HSTouch s that it can keep it very busy (see attached screenshot) as it is attempting to refresh device configurations to the point that HSTouch becomes unusable (cannot connect from clients or designer). See http://bugzilla.homeseer.com/bugzill...ug.cgi?id=1984 for additional details. I "Disable automatic polling" in the Insteon polling and that made it much better.
Can a future update of the plugin support polling without generating device configuration changes? Thanks
