Insteon Devices Missing
    #16
    Just to close the loop on my issue. I ended up having to reinstall all my devices. The good news is that the shells of all my events were still there so all I had to was reenter the device names in the right places and the logic was all still intact. I had a printout of the events from before and kept the device names consistent so this part went quickly.
      #17
      thanks for the feedback. still curious as to what happened
      Mark
      HS3 Pro 3.0.0.534
        #18
        Fixed
        I found my Insteon.ini listed no devices and I hadn't backed up that particular file in the past using Norton 360. I chose the best configuration file and also found the "missing" parts of my Insteon file was included in InsteonErrorReports in the Config subdirectory. I chose the best fit (newest) InsteonErrorReport and copied out the missing parts and pasted them into the Insteon.ini.
        It wasn't a perfect match to my current system but it gave me a place to start. It turned out that some of the Indexing in the InsteonErrorReports file was out of index so I had to check each item in the Events files and correct as needed but it brought me out of Never-Never Land. I also had to add some devices since I had made several major changes/additions just prior to the problem.
        Needless to say I am now backing up the Insteon.ini and Configuration file weekly. Previously I didn't realize that they weren't being backed up. Now I know!
        Still overall it worked out fine and I want to thank Mark for his great direction.
          #19
          Glad you got it working again.
          Mark
          HS3 Pro 3.0.0.534
