INSTEON 2663-222 ON/OFF (DUAL) OUTLET
    Mark - I just received and tested Insteon's brand new Dual Controlled Outlet 2663-222 with HomeSeer V2 and your wonderful PI. Was able to TAP-add the first / upper outlet to the PI & HomeSeer (its listed as a Device Type 0239) and responds to HS commands . However, I do not see controls for the second outlet and my attempts to TAP-add it are greeted with a message stating "the device has already been added."
    Poking around in Insteon's forums, I see you recently requested Device Notes on this new product. Did I miss an important setup procedure or is this device not quite ready for prime time use in HS2?
    Thanks for helping keep Insteon an affordable, easy and reliable choice for automation controls.
    Dan the LAN MAN
    what version of the hs2 plugin are you using
    Mark
    HS3 Pro 3.0.0.534
      I posted 2.0.0.15 to the hs2 beta thread. it should support the new device.
      Mark
      HS3 Pro 3.0.0.534
        INSTEON 2663-222 ON/OFF (DUAL) OUTLET - RESOLVED
        Mark - you are correct. I was using the HS2 Updater Site's Insteon P.I. by M.S. Release 2.0.0.4. After manually installing 2.0.0.15, I have full control of the new Insteon 2663 Dual Relay controlled receptacle.
        Thank you much! Dan the LAN Man
          glad its working. please respond if you find any issues with confirgation or control of the device.
          Mark
          HS3 Pro 3.0.0.534
            Mark,
            I realize this is an old post but I have a question for which I've been searching the forum, obviously not well enough.
            RE: INSTEON 2663-222 ON/OFF (DUAL) OUTLET. I have the HS3 ZEE S2 Edition 3.0.0.548. I have added the aforementioned dual AC/outlet manually by inputting its ID. My issue now is creating an "event" for it to turn on/off e.g. sunrise/sunset. When I go into View\Events all I see is lighting. Although I can see my other Insteon on/off lamp modules, Z-Wave LED light bulb, Z-Wave on/off switch in this category, and can set events for them, I do not see my 2663 Dual outlet anywhere. In the "Device List" I can manually turn it on/off. Do I need to "+" add an event? If I go into Insteon\Configuration I see it along with my other Insteon devices. BTW, how does Homeseer associate a smart device to "lighting" or any of the other categories? Thank you!
              Hey Derek
              what homeseer & plugin version are you running? You should be able to control the device using the standard homeseer control a device action.
              please feel free to start a new thread with a pic of th event you are working on and we will go from there.
              Mark
              HS3 Pro 3.0.0.534
                Hey Derek
                Hi,
                sorry for the delay. The Version of Insteon is 3.0.7.1 with HS4. I accidentally deleted the outlet device. So I went to Plugins\Insteon\Configuration\Manage Devices and then "Manually Add new device". Then entered the Insteon ID for the Insteon 2663-222. It added fine.
                My current issue is how to properly name things such that the devices, when I call on them for an event, do not have names that are exceedingly long. I've attached a couple of screenshots to illustrate how the name of the device, when I call on it, is somewhat "screwy". My third png that is attached shows it as "Upper outlet lower outlet". Clearly I'm doing something screwy in how I'm naming things.
                thx
                  that maybe an hs4 display issue. is there another entry in the device list that says "backyard upper outlet upper outlet"
                  can you even select upper and lower separately?
                  Mark
                  HS3 Pro 3.0.0.534
