Hi Mark,
I have an event in HS3 (3.0.0.149) who's (Insteon) trigger is device "Transmits an On command"; if triggered I then set the same device to Dim 20% after a delay of 10 seconds.
The trigger and the event work fine, except that, on setting the device to a Dim value, the event is re-triggered.
My understanding of the Insteon trigger "Transmits an On command" was that it was the result of a physical press on the switch, not a device control from HS. I need you to confirm this before I dig further into this.
Here are the event and part of the HS log
