Swapped out Interface-Stuff Stopped working
    mark,
    am using your insteon plug in v 3.0.5.10..
    my Serial plug in interface crapped out.. I ordered a new one.. used the swap interface button on the manage page..
    went through all devices but for some reason, about 20-30 of them did NOT get reprogrammed..The new interface is in the same outlet as the original, and the communication I had across the board was excellent/good.. never any poor or unreachable, since the new controller it cant talk to several devices..
    I tried regetting the links, and programming for homeseer, but it says the controller cant be reached.. please help.. half my system isn't working..
    whats the easiest way to resolve all this>.
    Originally posted by thetaz01 View Post
    mark,
    you can rerun the swap routine. it will only update devices with the old plm ID.
    Mark
    HS3 Pro 4.2.19.5
      So I went to do that when I got home last night,, However unfortunately, I already threw out the old PLM I don't remember the ID?? :-/
      what can/do I do now?
        No problem. Just look on the main config page, there should be a list of devices with unregistered Insteon IDs. One of these IDs must be the old PLM.
        Mark
        HS3 Pro 4.2.19.5
          The old PLM isn't plugged in anymore.. its gone..
          here is whats listed..
          The following are unregistered Insteon addresses found in the network.
          1C.FC.8B found in Access Control Driveway Entry
          1C.FC.8B found in Access Control Driveway Exit
          1C.FC.8B found in Attic East Gable Vent Fan
          1C.FC.8B found in Burner Room Light
          1C.FC.8B found in Cats Room Fluorescent Light
          1C.FC.8B found in Cats Room Night Light
          1C.FC.8B found in Cats Room Vent Fan
          1C.FC.8B found in Dining Room Ceiling Fan Light
          1C.FC.8B found in Dining Room South Wall Outlet (Xmas Lights)
          1C.FC.8B found in Dining Room Speakers
          1C.FC.8B found in Foyer Light
          1C.FC.8B found in Foyer Light (Slave)
          1C.FC.8B found in Foyer Main House Fan
          1C.FF.74 found in Foyer Main House Fan
          1C.FC.8B found in Foyer Night Light
          1C.FC.8B found in Fred Jrs Bathroom Fluorescent Light
          1C.FC.8B found in Fred Jrs Bedroom Bubble Lights
          1C.FC.8B found in Fred Jrs Bedroom Ceiling Fan
          1C.FC.8B found in Fred Jrs Bedroom Ceiling Fan Wall Switch
          1C.FC.8B found in Fred Jrs Bedroom Controller
          1C.FC.8B found in Fred Jrs Bedroom Humidifier
          1C.FC.8B found in Fred Jrs Bedroom Light
          1C.FC.8B found in Fred Jrs Bedroom Light (Slave)
          1C.FC.8B found in Fred Jrs Bedroom Small Closet Light
          21.D2.F5 found in Fred Jrs Bedroom Small Closet Light
          1C.FC.8B found in Fred Jrs Bedroom Walk in Closet Light
          1C.FC.8B found in Fred Jrs Hallway Light
          1C.FC.8B found in Fred Jrs Hallway Light (Slave)
          1C.FC.8B found in Fred Jrs Living Room Couch Light
          1B.4F.CE found in Fred Jrs Living Room Fluorescent Light
          1C.FC.8B found in Fred Jrs Living Room Fluorescent Light
          1D.56.61 found in Fred Jrs Living Room Fluorescent Light
          1C.FC.8B found in Fred Jrs Living Room Night Light
          1C.FC.8B found in Fred Jrs Living Room RemoteLinc
          1C.FC.8B found in Fred Jrs Living Room Survellance Monitor
          1C.40.36 found in Guest Room Christmas Lights
          1C.FC.8B found in Guest Room Table Lamp (Outlet)
          1D.CF.AE found in Guest Room Table Lamp (Outlet)
          1C.FC.8B found in Hallway Portable Fan
          1C.FC.8B found in House Smoke Bridge
          1C.FC.8B found in Kitchen Back Door Light
          1C.FC.8B found in Kitchen Light Over Table
          1C.FC.8B found in Living Room Christmas Lights
          1C.FC.8B found in Living Room Survellance Monitor
          1C.FC.8B found in Master Bathroom Light
          1C.FC.8B found in Master Bathroom Light (Slave)
          1C.40.36 found in Master Bedroom Air Conditioner
          1C.FC.8B found in Master Bedroom Ceiling Fan
          1C.FC.8B found in Master Bedroom Table Lamps
          1C.FC.8B found in Office Christmas Lights
          1C.FC.8B found in Office Day Light
          1C.FC.8B found in Office Fan
          1C.40.36 found in Outside Front Walkway Motion Light
          1C.FC.8B found in Outside Front Walkway Motion Light
          1C.40.36 found in Store Room Fluorescent Light
          1C.40.36 found in Store Room Reloading Tumbler
          1C.FC.8B found in Under Stairs Water Main Shutoff
          Externally registered device: 1B.02.CE (Insteon Address 1B.02.CE) registered through method
          Externally registered device: 1E.79.14 (Insteon Address 1E.79.14) registered through method
          Externally registered device: Fred Jrs Bedroom (Insteon Address 2C.10.FD) registered through method
          Externally registered device: Fred Jrs Living Room (Insteon Address 20.46.78) registered through method
          Externally registered device: Master Bedroom (Insteon Address 2C.0F.61) registered through method
          Externally registered device: Upstairs (Insteon Address 2C.0A.AB) registered through method
            1C.FC.8B is most likely the old PLM ID
            Mark
            HS3 Pro 4.2.19.5
              Ok, giving that a shot now..
              Im assuming that everything in that LIST should go away ONCE it has the new PLM ID correct?
                only entries with that ID will disappear. you can investigate the others.
                rerun the swap if it doesn't work 100%. the other option is to run the 'program device for homeseer' then delete the old links with the old PLM ID
                Mark
                HS3 Pro 4.2.19.5
                  Hmm, ok running it again seems to have made that list a lot smaller...
                  however still a few that aren't registered I will try running again and check the individual devices since the list is small now..
                  also I do have a question and this might NOT be something you can answer.. I am using the insteon thermostats, with the plug in but since the PLM change. my device references for the thermostats are gone, I was able to put a thermostat in link mode and have the plug in re-scan for it, but it didn't re-add the devices in the device page
                    glad you are making progress.
                    I have to refer you to the thermostat forum for help with the unit. I don't even use one myself.
                    Mark
                    HS3 Pro 4.2.19.5
                      ... I was able to put a thermostat in link mode and have the plug in re-scan for it, but it didn't re-add the devices in the device page
                      If you look in the HS log, you might find some error message from the Insteon thermostat plugin complaining that it can't connect to the thermostat. I believe links are handled by the thermostat plugin, so when you changed your PLM, Mark's swap routine doesn't address the thermostat.
                      Here's my suggestion (no guaranties):
                      1- If you can you find the hspi_insteon_thermostat.ini in "...\HomeSeer HS3\Config", first make a backup copy of it; actually, make a backup of everything, juts in case
                      2- In "Plug-ins\Insteon thermostat\Insteon thermostat Config", delete your old thermostat (if it still shows)
                      3- Then "Add new" in "Plug-ins\Insteon thermostat\Insteon thermostat Config": this should relink the thermostat to your new PLM
                      4- Bring down HS and overwrite the just created hspi_insteon_thermostat.ini with your previously saved copy: you should see your programs again, once you fire up HS
                        Thanks for helping him out Claude.
                        Under Plug-ins\Insteon thermostat\Insteon thermostat Config you should have a button option off to the right of your thermostat to "Update Links" The point of that is to write the necessary links into the PLM (via Mark's plugin) so that the PLM and thermostat can talk to each other.
                        Nathan
                        HS 3.0.0.435 (PRO)
                        Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
                        Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
                        Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
                        http://www.kazteel.com/
