Time to complete Event
    I'm not sure if this is specific to the insteon devices as that's mainly what I have to test, but is there away to adjust how long it takes the event to run?
    I currently have an 8-button keypadlinc and I have one of the buttons as "All On."
    I created an event in Homeseer so that when that button is pressed, it turns on all of the associated lights in the area. Right now for testing I'm just using two of those associated lights. When I press the button on the keypadlinc, I can count to 7 before the first light comes on (both on the keypadlinc and then its associated load) and then to 7 again before the next keypadlinc button light comes on, then about 4 seconds between the connected 3-way Switchlincs ramp up to full on.
    The event is simple:
    If the button has its value set to On,
    Then set light button 1 to On,
    Then set light button 2 to On.
    I also created crosslink links in the "manage devices" section for the keypadlinc for the associated keypadlinc button the 3-way switches. (There are 33 links for the keypadlinc).
    Is there anyway to make it more instant?
    Insteon Plugin version: 3.0.5.10
    HS3 Pro version 3.0.0.97
    Thanks!
    I would suggest this is not normal. If you don't have any defined delay for actions in the event, then these actions should fire up immediately or after a very short time (< 0.5-1 sec.).
    I would enable detailed logging on the Insteon plugin and watch for retries or any strange behavior.
      Here's the detailed log from the moment right before I hit the "all on" button.
      Jan-04 10:53:45 AM 	  	Insteon 	Starting Scheduled Polling...
      Jan-04 10:53:45 AM 	  	Insteon 	..Finished Scheduled Polling for 0 devices.
      Jan-04 10:53:31 AM 	  	Insteon 	Received a Direct ACK from Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48)
      Jan-04 10:53:31 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:31 AM 	  	Insteon 	Received message from Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48) taking hops: 1
      Jan-04 10:53:31 AM 	  	Insteon 	..My XML buffer begins with: 026228D8480F11FF06025028D8482CBCBE2F11FF
      Jan-04 10:53:31 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:31 AM 	  	Insteon 	..Got Hub Response 02 62 28 D8 48 0F 11 FF 06
      Jan-04 10:53:31 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):28 D8 48 2C BC BE 2F 11 FF
      Jan-04 10:53:30 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?026228D8480F11FF=I=3
      Jan-04 10:53:30 AM 	  	Insteon 	..Finished Scheduled Polling for 0 devices.
      Jan-04 10:53:30 AM 	  	Insteon 	Starting Scheduled Polling...
      Jan-04 10:53:30 AM 	  	Insteon 	Received message from Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48) taking hops: 1
      Jan-04 10:53:30 AM 	  	Insteon 	Sending command 02 62 28 D8 48 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:30 AM 	  	Insteon 	Received a Direct ACK from Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48)
      Jan-04 10:53:30 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:30 AM 	  	Insteon 	..Got Hub Response 02 62 28 D8 48 0F 11 FF 06
      Jan-04 10:53:30 AM 	  	Insteon 	..My XML buffer begins with: 026228D8480F11FF06025028D8482CBCBE2F11FF
      Jan-04 10:53:30 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:30 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):28 D8 48 2C BC BE 2F 11 FF
      Jan-04 10:53:29 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?026228D8480F11FF=I=3
      Jan-04 10:53:29 AM 	  	Insteon 	Received a Direct ACK from Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4)
      Jan-04 10:53:29 AM 	  	Insteon 	Received message from Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4) taking hops: 1
      Jan-04 10:53:29 AM 	  	Insteon 	Sending command 02 62 28 D8 48 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:29 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:29 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:29 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):28 D7 F4 2C BC BE 2F 11 FF
      Jan-04 10:53:29 AM 	  	Insteon 	..Got Hub Response 02 62 28 D7 F4 0F 11 FF 06
      Jan-04 10:53:29 AM 	  	Insteon 	..My XML buffer begins with: 026228D7F40F11FF06025028D7F42CBCBE2F11FF
      Jan-04 10:53:28 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?026228D7F40F11FF=I=3
      Jan-04 10:53:28 AM 	  	Insteon 	Received message from Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4) taking hops: 1
      Jan-04 10:53:28 AM 	  	Insteon 	Received a Direct ACK from Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4)
      Jan-04 10:53:28 AM 	  	Insteon 	Sending command 02 62 28 D7 F4 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:28 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:28 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):28 D7 F4 2C BC BE 2F 11 FF
      Jan-04 10:53:28 AM 	  	Insteon 	..Got Hub Response 02 62 28 D7 F4 0F 11 FF 06
      Jan-04 10:53:28 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:28 AM 	  	Insteon 	..My XML buffer begins with: 026228D7F40F11FF06025028D7F42CBCBE2F11FF
      Jan-04 10:53:27 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?026228D7F40F11FF=I=3
      Jan-04 10:53:27 AM 	  	Insteon 	Received message from Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD) taking hops: 1
      Jan-04 10:53:27 AM 	  	Insteon 	Received a Direct ACK from Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD)
      Jan-04 10:53:27 AM 	  	Insteon 	Sending command 02 62 28 D7 F4 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:27 AM 	  	Insteon 	..My XML buffer begins with: 026228D7AD0F11FF06025028D7AD2CBCBE2F11FF
      Jan-04 10:53:27 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:27 AM 	  	Insteon 	..Got Hub Response 02 62 28 D7 AD 0F 11 FF 06
      Jan-04 10:53:27 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):28 D7 AD 2C BC BE 2F 11 FF
      Jan-04 10:53:27 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:26 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?026228D7AD0F11FF=I=3
      Jan-04 10:53:26 AM 	  	Insteon 	Received message from Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD) taking hops: 1
      Jan-04 10:53:26 AM 	  	Insteon 	Received a Direct ACK from Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD)
      Jan-04 10:53:26 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:26 AM 	  	Insteon 	Sending command 02 62 28 D7 AD 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:26 AM 	  	Insteon 	..My XML buffer begins with: 026228D7AD0F11FF06025028D7AD2CBCBE2F11FF
      Jan-04 10:53:26 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:26 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):28 D7 AD 2C BC BE 2F 11 FF
      Jan-04 10:53:26 AM 	  	Insteon 	..Got Hub Response 02 62 28 D7 AD 0F 11 FF 06
      Jan-04 10:53:25 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?026228D7AD0F11FF=I=3
      Jan-04 10:53:25 AM 	  	Insteon 	Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 1
      Jan-04 10:53:25 AM 	  	Insteon 	Received a Direct ACK from Living Room KeypadLinc Dimmer (33.0E.C2)
      Jan-04 10:53:25 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:25 AM 	  	Insteon 	Sending command 02 62 28 D7 AD 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:25 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:25 AM 	  	Insteon 	..Got Hub Response 02 62 33 0E C2 1F 2E 00 00 09 07 00 00 00 00 00 00 00 00 00 00 C2 06
      Jan-04 10:53:25 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):33 0E C2 2C BC BE 2B 2E 00
      Jan-04 10:53:25 AM 	  	Insteon 	..My XML buffer begins with: 0262330EC21F2E0000090700000000000000000000C2060250330EC22CBCBE2B2E
      Jan-04 10:53:24 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?0262330EC21F2E0000090700000000000000000000C2=I=3
      Jan-04 10:53:24 AM 	  	Insteon 	Setting status and value for device 28.D8.48:1. Old status:100 Old Value:100, New Status:2 New Value:100
      Jan-04 10:53:24 AM 	  	Insteon 	Sending sync command to linked responder device: Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48)
      Jan-04 10:53:24 AM 	  	Insteon 	Setting status and value for device 28.D8.48:1. Old status:0 Old Value:0, New Status:2 New Value:100
      Jan-04 10:53:24 AM 	  	Insteon 	Setting status and value for device 28.D7.F4:1. Old status:100 Old Value:100, New Status:2 New Value:100
      Jan-04 10:53:24 AM 	  	Insteon 	Sending sync command to linked responder device: Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4)
      Jan-04 10:53:24 AM 	  	Insteon 	Setting status and value for device 28.D7.F4:1. Old status:0 Old Value:0, New Status:2 New Value:100
      Jan-04 10:53:24 AM 	  	Insteon 	Setting status and value for device 28.D7.AD:1. Old status:100 Old Value:100, New Status:2 New Value:100
      Jan-04 10:53:24 AM 	  	Insteon 	Sending sync command to linked responder device: Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD)
      Jan-04 10:53:24 AM 	  	Insteon 	Setting status and value for device 28.D7.AD:1. Old status:0 Old Value:0, New Status:2 New Value:100
      Jan-04 10:53:24 AM 	  	Insteon 	SyncResponderDevices called for device code: 33.0E.C2:3
      Jan-04 10:53:24 AM 	  	Insteon 	Sending command 02 62 33 0E C2 1F 2E 00 00 09 07 00 00 00 00 00 00 00 00 00 00 C2 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:24 AM 	  	Insteon 	Checking for keypadlinc button sync on device 33.0E.C2 src index 3, SrcIsSyncTarget=True...
      Jan-04 10:53:24 AM 	  	Insteon 	Setting status and value for device 33.0E.C2:3. Old status:0 Old Value:0, New Status:2 New Value:100
      Jan-04 10:53:24 AM 	  	Insteon 	Received a Direct ACK from Living Room KeypadLinc Dimmer (33.0E.C2)
      Jan-04 10:53:24 AM 	  	Insteon 	Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 1
      Jan-04 10:53:24 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:24 AM 	  	Insteon 	..My XML buffer begins with: 0262330EC20F1901060250330EC22CBCBE2B3803
      Jan-04 10:53:24 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:24 AM 	  	Insteon 	..Got Hub Response 02 62 33 0E C2 0F 19 01 06
      Jan-04 10:53:24 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):33 0E C2 2C BC BE 2B 38 03
      Jan-04 10:53:23 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?0262330EC20F1901=I=3
      Jan-04 10:53:23 AM 	  	Insteon 	Received a Direct ACK from Living Room KeypadLinc Dimmer (33.0E.C2)
      Jan-04 10:53:23 AM 	  	Insteon 	SyncResponderDevices called for device code: 33.0E.C2:1
      Jan-04 10:53:23 AM 	  	Insteon 	Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 1
      Jan-04 10:53:23 AM 	  	Insteon 	Sending command 02 62 33 0E C2 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:23 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:23 AM 	  	Insteon 	..Got Hub Response 02 62 33 0E C2 0F 11 FF 06
      Jan-04 10:53:23 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):33 0E C2 2C BC BE 2B 11 FF
      Jan-04 10:53:23 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:23 AM 	  	Insteon 	..My XML buffer begins with: 0262330EC20F11FF060250330EC22CBCBE2B11FF
      Jan-04 10:53:22 AM 	  	Insteon 	Sending http://192.168.1.35:30001/3?0262330EC20F11FF=I=3
      Jan-04 10:53:22 AM 	  	Insteon 	Attempting to get a KPL LED status response from Insteon device 33.0E.C2
      Jan-04 10:53:22 AM 	  	Insteon 	CAPIControl: Label=On, Value=100, ControlType=Button
      Jan-04 10:53:22 AM 	  	Insteon 	Sending command 02 62 33 0E C2 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jan-04 10:53:22 AM 	  	Insteon 	Checking for keypadlinc button sync on device 33.0E.C2 src index 1, SrcIsSyncTarget=True...
      Jan-04 10:53:22 AM 	  	Insteon 	Setting status and value for device 33.0E.C2:1. Old status:0 Old Value:0, New Status:2 New Value:100
      Jan-04 10:53:22 AM 	  	Insteon 	Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 2
      Jan-04 10:53:22 AM 	  	Insteon 	Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 1
      Jan-04 10:53:22 AM 	  	Insteon 	Checking for keypadlinc button sync on device 33.0E.C2 src index 2, SrcIsSyncTarget=True...
      Jan-04 10:53:22 AM 	  	Insteon 	Setting status and value for device 33.0E.C2:2. Old status:0 Old Value:0, New Status:2 New Value:100
      Jan-04 10:53:22 AM 	  	Insteon 	ProcessGroupBroadcast: Device Living Room KeypadLinc Dimmer Button B: All On (33.0E.C2) is group broadcast source (tgt group/button:2) sending cmd 11
      Jan-04 10:53:22 AM 	  	Insteon 	Received 33.0E.C2:2 (Living Room All On) Go ON
      Jan-04 10:53:22 AM 	  	Insteon 	PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
      Jan-04 10:53:22 AM 	  	Insteon 	Sending http://192.168.1.35:30001/1?XB=M=1
      Jan-04 10:53:22 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):33 0E C2 00 00 02 C7 11 00
      Jan-04 10:53:22 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):33 0E C2 00 01 02 CB 11 02
      Jan-04 10:53:22 AM 	  	Insteon 	Received STX 0x50 (Raw Insteon Rec):33 0E C2 11 00 02 C7 06 00
      Jan-04 10:53:22 AM 	  	Insteon 	..My XML buffer begins with: 0250330EC2000002C711000250330EC2000102CB11020250330EC2110002C706
      Jan-04 10:53:15 AM 	  	Insteon 	..Finished Scheduled Polling for 0 devices.
      Jan-04 10:53:15 AM 	  	Insteon 	Starting Scheduled Polling...
      Jan-04 10:53:00 AM 	  	Insteon 	..Finished Scheduled Polling for 0 devices.
      Jan-04 10:53:00 AM 	  	Insteon 	Starting Scheduled Polling...
        Originally posted by ckellyusa View Post
        Here's the detailed log from the moment right before I hit the "all on" button....
        Mark would be better answering this since he knows the plugin logic, but here are my observations.
        1- status & value are set twice for each of the 3 devices, resulting in duplicate On commands; example:
        Jan-04 10:53:24 AM Insteon Setting status and value for device 28.D8.48:1. Old status:100 Old Value:100, New Status:2 New Value:100<O></O>
        Jan-04 10:53:24 AM Insteon Sending sync command to linked responder device: Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48)<O></O>
        Jan-04 10:53:24 AM Insteon Setting status and value for device 28.D8.48:1. Old status:0 Old Value:0, New Status:2 New Value:100<O></O>
        By any chance, do you have groups defined involving those devices? Also, if you've cross-linked the 3 devices with that KPL button, why have an HS event on top of that?
        2- You most likely have GetXMLBufferInterval=1000 in your Insteon.ini. My understanding is that the plugin will poll the hub every 1 second, so given the number of interactions, delays add up. The log shows you're seeing the first light On after 4 seconds, not 7, but still a long wait time. Reducing the interval will speed up things but chew up more cycles and TCP/IP bandwidth.
          the best way to get instant reaction from the kpl btn to the other devices is to create a group in the plugin and assign the kpl btn as the controller and then assign the other devices as responders. No hs event/actions required. you can add additional responders later, but you can't change the controller without deleting and recreating the group.
          Mark
          HS3 Pro 3.0.0.534
            OK, 2 things:
            1. When I create a new group and click "Add and Program Group", it takes me to the next page where it is programming the links and says it'll auto-refresh and not to do anything until it shows the continue button. The programming page looks like it's missing some CSS code or something as it's all displayed wrong and then it never changes to the "continue" screen. After waiting about 15 mins I went back to manage plug-ins, then click on Insteon Configuration link where I found the continue page.
            2. What am I doing? haha. I guess, what is the correct way to setup what I'm trying to do.....
            The physical setup:
            8-button keypadlinc installed, load connected to living room lights
            4-way (3 switches) Switchlinc Dimmer installed in kitchen
            On-off modules install on various lamps
            Switchlinc Dimmer installed in Entryway
            What I want to do:
            1. Press one of the buttons on the keypadlinc labeled All On and it turns on all of the above mentioned lights.
            2. Using HSTouch, activate the All On button and have all above mentioned lights turn on
            3. Have the other buttons on the keypadlinc synced with the other various lights so if I turn the kitchen lights on using the switchlinc, the kitchen light labeled button lights up as well. (and vise-versa)
            What I currently have works, but with major delays:
            I created a group with the All On button as the controller and added each of the other buttons as participants. Is that the correct way?
            I think there are too many links for some reason:
            Living Room KeypadLinc Dimmer (33.0E.C2):
            ->Button2 controls Living Room KeypadLinc Dimmer (33.0E.C2) (1-way)
            ->Button3 controls Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD). Button1 reflects back (2-way)
            ->Button3 controls Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48). Button1 reflects back (2-way)
            ->Button3 controls Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4). Button1 reflects back (2-way)
            Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD):
            ->Button1 controls Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48). Button1 reflects back (2-way)
            ->Button1 controls Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4). Button1 reflects back (2-way)
            ->Button1 controls Living Room KeypadLinc Dimmer (33.0E.C2). Button3 reflects back (2-way)
            Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48):
            ->Button1 controls Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD). Button1 reflects back (2-way)
            Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4):
            and
            Device Link Table
            Link #37 Button B controls Living Room KeypadLinc Dimmer (33.0E.C2)
            Link #40 Button B controls Living Room KeypadLinc Dimmer Button C (33.0E.C2)
            Link #43 Button B controls Living Room KeypadLinc Dimmer Button D (33.0E.C2)
            Link #46 Button B controls Living Room KeypadLinc Dimmer Button E (33.0E.C2)
            Link #49 Button B controls Living Room KeypadLinc Dimmer Button F (33.0E.C2)
            Link #52 Button B controls Living Room KeypadLinc Dimmer Button G (33.0E.C2)
            Link #55 Button B controls Living Room KeypadLinc Dimmer Button H (33.0E.C2)
            Link #29 Button C controls Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD)
            Link #23 Button C controls Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) Unknown Group/Button Name #3 (28.D7.AD)
            Link #31 Button C controls Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4)
            Link #27 Button C controls Kitchen SwitchLinc Dimmer (High Wattage) Laundry Unknown Group/Button Name #3 (28.D7.F4)
            Link #33 Button C controls Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48)
            Link #25 Button C controls Kitchen SwitchLinc Dimmer (High Wattage) MR Unknown Group/Button Name #3 (28.D8.48)
            Link #3 Button A/Load has local control reporting to HomeSeer
            Link #6 Button A/Load has local control reporting to HomeSeer
            Link #7 Button B has local control reporting to HomeSeer
            Link #8 Button C has local control reporting to HomeSeer
            Link #9 Button D has local control reporting to HomeSeer
            Link #10 Button E has local control reporting to HomeSeer
            Link #11 Button F has local control reporting to HomeSeer
            Link #12 Button G has local control reporting to HomeSeer
            Link #13 Button H has local control reporting to HomeSeer
            Link #5 Button A/Load is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level 0%, Ramp Rate .5 Sec.
            Link #2 Button A/Load is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level 100%, Ramp Rate .5 Sec.
            Link #4 Button A/Load is controlled by HomeSeer using Hub Group #1 (Button Control Group) - On Level 100%, Ramp Rate .5 Sec.
            Link #15 Button A/Load is controlled by HomeSeer using Hub Group #12 (Button Control Group) - On Level 100%, Ramp Rate .1 Sec.
            Link #35 Button A/Load is controlled by HomeSeer using Hub Group #20 Registered Group #2 'House Living Room Keypad Controller' - On Level 100%, Ramp Rate .1 Sec.
            Link #14 Button A/Load is controlled by HomeSeer using Hub Group #254 (HomeSeer All Devices Group) - On Level 100%, Ramp Rate .1 Sec.
            Link #36 Button A/Load is controlled by Living Room KeypadLinc Dimmer Button B (33.0E.C2) - On Level 100%, Ramp Rate .1 Sec.
            Link #1 Button A/Load is controlled by Unregistered Device Group 1 (1B.FF.27) - On Level 100%, Ramp Rate .5 Sec.
            Link #16 Button B is controlled by HomeSeer using Hub Group #13 (Button Control Group) - Command: On
            Link #17 Button C is controlled by HomeSeer using Hub Group #14 (Button Control Group) - Command: On
            Link #38 Button C is controlled by HomeSeer using Hub Group #20 Registered Group #2 'House Living Room Keypad Controller' - Command: On
            Link #24 Button C is controlled by Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD) - Command: On
            Link #30 Button C is controlled by Kitchen Dual-Band SwitchLinc Dimmer (High Wattage) (28.D7.AD) - Command: On
            Link #28 Button C is controlled by Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4) - Command: On
            Link #32 Button C is controlled by Kitchen SwitchLinc Dimmer (High Wattage) Laundry (28.D7.F4) - Command: On
            Link #26 Button C is controlled by Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48) - Command: On
            Link #34 Button C is controlled by Kitchen SwitchLinc Dimmer (High Wattage) MR (28.D8.48) - Command: On
            Link #39 Button C is controlled by Living Room KeypadLinc Dimmer Button B (33.0E.C2) - Command: On
            Link #18 Button D is controlled by HomeSeer using Hub Group #15 (Button Control Group) - Command: On
            Link #41 Button D is controlled by HomeSeer using Hub Group #20 Registered Group #2 'House Living Room Keypad Controller' - Command: On
            Link #42 Button D is controlled by Living Room KeypadLinc Dimmer Button B (33.0E.C2) - Command: On
            Link #19 Button E is controlled by HomeSeer using Hub Group #16 (Button Control Group) - Command: On
            Link #44 Button E is controlled by HomeSeer using Hub Group #20 Registered Group #2 'House Living Room Keypad Controller' - Command: On
            Link #45 Button E is controlled by Living Room KeypadLinc Dimmer Button B (33.0E.C2) - Command: On
            Link #20 Button F is controlled by HomeSeer using Hub Group #17 (Button Control Group) - Command: On
            Link #47 Button F is controlled by HomeSeer using Hub Group #20 Registered Group #2 'House Living Room Keypad Controller' - Command: On
            Link #48 Button F is controlled by Living Room KeypadLinc Dimmer Button B (33.0E.C2) - Command: On
            Link #21 Button G is controlled by HomeSeer using Hub Group #18 (Button Control Group) - Command: On
            Link #50 Button G is controlled by HomeSeer using Hub Group #20 Registered Group #2 'House Living Room Keypad Controller' - Command: On
            Link #51 Button G is controlled by Living Room KeypadLinc Dimmer Button B (33.0E.C2) - Command: On
            Link #22 Button H is controlled by HomeSeer using Hub Group #19 (Button Control Group) - Command: On
            Link #53 Button H is controlled by HomeSeer using Hub Group #20 Registered Group #2 'House Living Room Keypad Controller' - Command: On
            Link #54 Button H is controlled by Living Room KeypadLinc Dimmer Button B (33.0E.C2) - Command: On
            Thanks for your help!
              1. please checkout this thread regarding your css/refresh issue:
              http://board.homeseer.com/showthread.php?t=171567
              2. there is a sticky thread on how to use KPL btns for various scenarios.
              - you might consider creating a group that is controlled by the KPL btn. Then on the kpl device edit page, there is an "HS Control" option to 'trigger group' which control the group from HS
              Mark
              HS3 Pro 3.0.0.534
                Ok, I think I followed the directions correctly, but I can't seem to get it to work.
                When I press the button on the keypadlinc, nothing happens.
                I used this thread: http://board.homeseer.com/showthread.php?t=151193 as a guide.
                Here is what my group program looks like currently (simplified for testing)
                And here's the log file when I press the "All On" button on the KeypadLinc.
                Feb-27 3:00:54 PM           Insteon     Setting status and value for device 33.0E.C2:2. Old status:0 Old Value:0, New Status:2 New Value:100
                Feb-27 3:00:54 PM           Insteon     Checking for keypadlinc button sync on device 33.0E.C2 src index 2, SrcIsSyncTarget=True...
                Feb-27 3:00:54 PM           Insteon     ProcessGroupBroadcast: Updating Group #2 status
                Feb-27 3:00:54 PM           Insteon     Setting value for Group:20
                Feb-27 3:00:54 PM           Insteon     Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 1
                Feb-27 3:00:54 PM           Insteon     ..My XML buffer begins with: 0250330EC2000002C711000250330EC2000102CB1102
                Feb-27 3:00:54 PM           Insteon     Sending http://192.168.1.35:30001/1?XB=M=1
                Feb-27 3:00:54 PM           Insteon     Received STX 0x50 (Raw Insteon Rec):33 0E C2 00 00 02 C7 11 00
                Feb-27 3:00:54 PM           Insteon     Received STX 0x50 (Raw Insteon Rec):33 0E C2 00 01 02 CB 11 02
                Feb-27 3:00:54 PM           Insteon     PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                Feb-27 3:00:54 PM           Insteon     Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 2
                Feb-27 3:00:54 PM           Insteon     Received 33.0E.C2:2 (Living Room All On) Go ON
                Feb-27 3:00:54 PM           Insteon     ProcessGroupBroadcast: Device Living Room KeypadLinc Dimmer Button B: All On (33.0E.C2) is group broadcast source (tgt group/button:2) sending cmd 11
                Feb-27 3:00:45 PM           Insteon     Setting status and value for device 33.0E.C2:2. Old status:100 Old Value:100, New Status:3 New Value:0
                Feb-27 3:00:45 PM           Insteon     Checking for keypadlinc button sync on device 33.0E.C2 src index 2, SrcIsSyncTarget=True...
                Feb-27 3:00:45 PM           Insteon     ProcessGroupBroadcast: Updating Group #2 status
                Feb-27 3:00:45 PM           Insteon     Setting value for Group:20
                Feb-27 3:00:45 PM           Insteon     Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 1
                Feb-27 3:00:45 PM           Insteon     Received 33.0E.C2:2 (Living Room All On) Go OFF
                Feb-27 3:00:45 PM           Insteon     ProcessGroupBroadcast: Device Living Room KeypadLinc Dimmer Button B: All On (33.0E.C2) is group broadcast source (tgt group/button:2) sending cmd 13
                Feb-27 3:00:45 PM           Insteon     ..My XML buffer begins with: 0250330EC2000002C713000250330EC2000102CB13020250330EC2130002CB06
                Feb-27 3:00:45 PM           Insteon     Sending http://192.168.1.35:30001/1?XB=M=1
                Feb-27 3:00:45 PM           Insteon     Received STX 0x50 (Raw Insteon Rec):33 0E C2 00 00 02 C7 13 00
                Feb-27 3:00:45 PM           Insteon     Received STX 0x50 (Raw Insteon Rec):33 0E C2 00 01 02 CB 13 02
                Feb-27 3:00:45 PM           Insteon     Received STX 0x50 (Raw Insteon Rec):33 0E C2 13 00 02 CB 06 00
                Feb-27 3:00:45 PM           Insteon     PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                Feb-27 3:00:45 PM           Insteon     Received message from Living Room KeypadLinc Dimmer (33.0E.C2) taking hops: 2
                  if pressing the kpl btn (the controller) doesn't work, then the links didn't get written correctly. is there a link on the switchlinc that indicates its controlled by the correct kpl btn?
                  Mark
                  HS3 Pro 3.0.0.534
                    I think this is the link:
                    Insteon Device ID: 28.D7.F4
                    Link #10  Switch/Load  is controlled by HomeSeer using Hub Group #20 Registered Group #2  'House Living Room All On' - On Level 100%, Ramp Rate .1 Sec.
                      does the light go on/off when you use the hs group device (on/off). for get about the kpl btn for a moment
                      Mark
                      HS3 Pro 3.0.0.534
                        I think you're asking if the SwitchLinc Dimmer works by itself, correct? It does, I can toggle it on and off through HS Device page and by physically pressing the SwtichLinc.
                          not exactly. when you create an insteon group, the plugin creates a hs device to control the group. please test this group device on/off
                          Mark
                          HS3 Pro 3.0.0.534
                            Gotcha! Found that and tested it, it was working. I'm not sure what happened but I played with the kpl button again and it was activating the switchlinc now, so I updated the group to include the 4-way switchs that had the load connected and so far that part works.
                            So with that working I added the load from the kpl to the group. It works from the hs device group, but not from the physical kpl button. Getting closer!
                              if you want to control the kpl load from another btn other than the on/off, you need to manually connect that btn to the On btn (its not a link). see the kpl manual for this.
                              Mark
                              HS3 Pro 3.0.0.534
