I'm just starting out with Insteon. I have several switches, keys, etc. They are all set to x10 and I'm moving to setting them to Insteon with a v1 hub. Can I use the Insteon App and setup the devices and then also use HS and Mark's plug-in at the same time? I think the only way to do this is to add the devices via the app and then have mark's plug-in query the links from the hub, is that correct?
On a side note, ignoring the question above, is it better to manually link Insteon controller and resoponders or should I use the plug-in to do the setup? What's the pros/cons of each?
Thank you.
Thank you.
