Is there any reason I can't use buttons as opposed to the dropdown in the main HS status page to trigger the on/off of an insteon group? (which I prefer to think of as a scene) And for that matter the rest of the controls should be available to be buttons as well.
I also notice that if I rename the HS device, it doesn't update the group in the plugin config page. Also, if I do rename it in the plugin setup, the only way to apply the name change is to reprogram the group. It appears that it doesn't actually do any programming of the devices, but the button label made me think as I pressed it.
