How to read an Insteon device in a script
This topic is closed.
    Hi Mark,
    The if hs.IsOn on an Insteon device seems that is not triggering. Could you please take a look at the the if below and let me know what I'm missing?
    This is my device:
    Occupancy Button A 13.C1.F2:3 Insteon KeypadLinc V2 Relay Button A Today 1:54:02 PM
    'if Occupancy Button A - Insteon Ref117 is On
    hs.WriteLog("BLRadarLastEcho", "Device" & hs.DeviceExistsRef(splitArray(3)))
    If hs.IsOn(hs.DeviceExistsRef(splitArray(3))) Then
    are you sure splitarray(3) is returning an integer device reference
    as a test, hardcode the devf ref in the hs.ison(x) call to see if that is working as expected
    Mark
    HS3 Pro 4.2.19.5
      Sorry my coding is terrible. I hard coded it as below. The device is on but I do not see the log.
      I'm attaching the device as well.
      If hs.IsOn(117) Then
      hs.WriteLog("BLRadarLastEcho", "Occupancy Button A On")
      'if A4 People Occupancy off
      If hs.IsOff(hs.DeviceExistsRef(splitArray(4))) Then
      hs.WriteLog("BLRadarLastEcho", "RunEvent HouseVacancy" )
      hs.TriggerEvent(splitArray(2))
      End If
      End If
        try
        if hs.DeviceValueEx(117) > 0 then
        i seem to recall ison & isoff don't work correct. you can report that do hst
        Mark
        HS3 Pro 4.2.19.5
