Help with this script please
    I would like to write a script that based on the light level of the motion sensor it will set the Hue level of brightness higher or lower based on the script example of JowiHue. I had similar script that was working in HS2. Unfortunately not really good at scripts. Can someone please help based on the prototype below. I'm open to suggestions to get the level of light more efficient instead of if statements.
    Syntax:
    Dim test As Boolean = hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, "All Lights", Nothing, 65535, 255, 20})
    Sub Main(parm as object)
    ' LightlevelStatus is going to be a string value
    ' the theory is that if there is lot of sun you want to see the lights on the keypad while if dark you want to dim it for eye pleasure
    ' Motion sensor Dining Room
    LightlevelStatus = hs.plugin("Insteon").getdevicesetting("14.1A.AF","Current Light Level")
    'hs.WriteLog "LightLevelDining", LightlevelStatus
    'so you need to convert it to an integer here
    If cint(LightlevelStatus) >= 100 Then
    ElseIf cint(LightlevelStatus) >= 80 Then
    ElseIf cint(LightlevelStatus) >= 60 Then
    ElseIf cint(LightlevelStatus) >= 40 Then
    Else
    End If
    End Sub
    for HS3, it should be something like
    LightlevelStatus = hs.plugin("Insteon","","getdevicesetting", new object(){14.1A.AF","Current Light Level"})
    i believe the new object() is required to designate a new array
    Mark
    HS3 Pro 3.0.0.534
      Mark I'm getting this error, do you know what this mean
      Dim LightlevelStatus As Integer
      LightlevelStatus = hs.pluginFunction("Insteon","","getdevicesetting", new object(){14.1A.AF","Current Light Level"})
      End Sub
      Mar-08 10:48:13 AM Error Compiling script C:\HomeSeer3\scripts\KeyPadLincBrightness.vb: '}' expected.
      Mar-08 10:48:13 AM Error Compiling script C:\HomeSeer3\scripts\KeyPadLincBrightness.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
        End Sub
        i think youre missing a quote
        "14.1A.AF"
        Mark
        HS3 Pro 3.0.0.534
          this is tested:
          Dim LightlevelStatus As string
          LightlevelStatus = hs.pluginFunction("Insteon","","GetDeviceSetting", new object(){"27.8E.79","Current Light Level"})
          hs.writelog ("test", lightlevelstatus)
          End Sub
          the call is case-sensitive and returns a string
          you can convert to an integer with
          level = cint(LightlevelStatus)
          Mark
          HS3 Pro 3.0.0.534
            aldo,
            You can do this with scripts, which gives you the simplicity of having to use only one event. I have done the same as you did, but instead I did it with a group holding 6 events which trigger basesd on group conditions and light level.
            I have attached my event which is setting the brightness level of the Hue lights. it is taking the light level from a zwave multisensor, but I am sure you can check the value also from a insteon device.
            Not sayin one is better then the other, just adding a sample on how you could look at the same issue.
            Wim
            -- Wim
              You guys are the best, sorry for bothering you sooooooo much.
                No problem. glad you got it working
                Mark
                HS3 Pro 3.0.0.534
