Do you guys use Events or Group in Insteon plug-in to control multiple devices?
I created an event in HS3 to turn on multiple Insteon devices when a button is pressed.
for example, I have a 6 button keypad at the main entry door, i want to use the "A" button to turn ON all the lights at downstairs, there are 4 devices.
but only 2 of the 4 responded every time.
I can't figure out why it's doing this. the other 2 that didn't respond are LOAD switches, default on level set to 100%, and "sync linked devices" checked.
also because it's a 6 button, how do you program it so both ON and OFF buttons can control the same group of devices?
