Originally posted by Bill Grant
View Post
HS3 Insteon Plug-In Version 3.0.5.20 Release (Windows & Linux)
Mark
HS3 Pro 4.2.19.5
Is it still recommended to use HS3 3.0.0.152 with this Insteon 3.0.5.20 update? I see they released HS3 3.0.0.181 (windows) in late May and I need to do a significant HS3 upgrade (from HS3 3.0.0.96) and would like to be as compatible as possible.
NathanHS 3.0.0.435 (PRO)
Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
http://www.kazteel.com/
Originally posted by nfrobertson View PostIs it still recommended to use HS3 3.0.0.152 with this Insteon 3.0.5.20 update? I see they released HS3 3.0.0.181 (windows) in late May and I need to do a significant HS3 upgrade (from HS3 3.0.0.96) and would like to be as compatible as possible.
Nathan
just make a backup of everything is case something goes south
hs db & insteon.ini are important to the insteon pluginMark
HS3 Pro 4.2.19.5
I used Oracle Virtual Box to create and run a Debian 8.1.0 VM on top of my Windows 7 HS3 dev box. I was able to use the Virtual Box to map the USB PLM (was on windows COM6) and when Debian mounted it, it showed up as /dev/ttyUSB0 and I was able to successfully use that. I believe Virtual Box has it's own USB driver used for this mapping so maybe that explains why this works.
I initially copied over my insteon.ini from my Windows 7 HS3 test machine and just updated the port. When I installed and started 3.0.5.20, it complained about no port. After looking at what it created, I saw the issue. It created Insteon.ini (uppercase I) not insteon.ini. I stopped the plugin, deleted the new one, moved my lowercase insteon.ini to Insteon.ini and edited the port to /dev/ttyUSB0. When it came up my handful of test Insteon devices worked with HS3. Cool.
I did notice one warning after I begain using this plugin on Linux:
12:00:02:8841:[Warning]->File does not exist: /opt/homeseer/HomeSeer/html/images/HomeSeer/5-x-5_trans_spacer.gif
But I did see the installer claimed it installed that file
11:43:01:5161:[Updater]->Starting download of updates
11:43:01:5165:[Updater]->Downloading update: Insteon
11:43:02:2622:[Updater]->Update HSPI_Insteon.exe downloaded successfully
11:43:02:2651:[Updater]->Installing package Insteon
11:43:02:3448:[Updater]->Copying file: \opt\homeseer\HomeSeer\HSPI_Insteon.exe
11:43:02:3462:[Updater]->Copying file: \opt\homeseer\HomeSeer\Insteon.dll
11:43:02:3529:[Updater]->Copying file: \opt\homeseer\HomeSeer\FTD2XX_NET.dll
11:43:02:3536:[Updater]->Making dir: \opt\homeseer\HomeSeer\html\images\homeseer\
11:43:02:3555:[Updater]->Copying file: \opt\homeseer\HomeSeer\html\images\homeseer\5-x-5_trans_spacer.gif
11:43:02:3599:[Updater]->Making dir: \opt\homeseer\HomeSeer\Scripts\
11:43:02:3602:[Updater]->Copying file: \opt\homeseer\HomeSeer\Scripts\Insteon_ExtDevSupport_Sample. vb
11:43:02:3607:[Updater]->Install/Update of package Insteon was successful.
so that prompted me to go exploring
I think this may be another issue with case-sensitivity on Linux. See the lowercase homeseer dir below with a timestamp matching the plugin install.
root@debianvm:/opt/homeseer/HomeSeer/html/images# ls -alF | grep -i homeseer
drwxr-xr-x 2 root root 4096 Jun 13 11:43 homeseer/
drwxr-xr-x 4 nathan nathan 4096 Nov 21 2014 HomeSeer/
root@debianvm:/opt/homeseer/HomeSeer/html/images# ls -alF homeseer
total 12
drwxr-xr-x 2 root root 4096 Jun 13 11:43 ./
drwxr-xr-x 14 nathan nathan 4096 Jun 13 11:43 ../
similar issue with scripts vs Scripts but this time the all lowercase scripts seems to be what HS3 wants:
root@debianvm:/opt/homeseer/HomeSeer# ls -alF | grep -i scripts
drwxr-xr-x 2 nathan nathan 4096 Nov 21 2014 scripts/
drwxr-xr-x 2 root root 4096 Jun 13 11:43 Scripts/
root@debianvm:/opt/homeseer/HomeSeer# ls -alF Scripts
total 24
drwxr-xr-x 19 nathan nathan 4096 Jun 13 11:43 ../
-rw-r--r-- 1 root root 15576 Feb 3 2007 Insteon_ExtDevSupport_Sample.vb
Thanks for all your hard work on this Mark!
Next step for me is to try my Insteon Thermostat plugin and see how much work I need to do to make it Linux compatible.
Nathan,
the case sensitivity is going to be an issue i may not be able to resolve. if for some reason the case is different in the OS than what i have set in the plugin then there is going to be a problem.
do i just need to publish the name conventions I'm expecting?
suggestions welcome.Mark
HS3 Pro 4.2.19.5
I just hit the same issue with my Insteon Thermostat plugin with the file Install.txt Kinda an important one. Apparently Linux is expecting all lowercase install.txt while windows doesn't give a bleep. Since that kept me from even installing my plugin I had to address it by adjusting the file I included in my plugin zip distro to just install.txt.
I only saw those two examples with your distribution. I think if you make the target directories match, case-wise, with what the Linux version of HS3 expects then it'll work in both Linux and Windows.
Originally posted by nfrobertson View PostI just hit the same issue with my Insteon Thermostat plugin with the file Install.txt Kinda an important one. Apparently Linux is expecting all lowercase install.txt while windows doesn't give a bleep. Since that kept me from even installing my plugin I had to address it by adjusting the file I included in my plugin zip distro to just install.txt.
NathanMark
HS3 Pro 4.2.19.5
I am only referring to those files you distribute with your plugin and the directories they need to go into, namely the two issues I pointed out above. They should all be relative to wherever the user is running HS3 from on their Linux box.
I'm not sure I know what you mean by default naming convention, can you please describe?HS 3.0.0.435 (PRO)
Nathan,
i thought hs3 set some of the folder names with mixed case like
"\images\HomeSeer"Mark
HS3 Pro 4.2.19.5
Right. What I'm saying is in your install.txt, the last two lines look like:
Code:5-x-5_trans_spacer.gif,.\html\images\homeseer,16 Insteon_ExtDevSupport_Sample.vb,.\Scripts,16
Code:5-x-5_trans_spacer.gif,.\html\images\[COLOR=red]H[/COLOR]ome[COLOR=red]S[/COLOR]eer,16 Insteon_ExtDevSupport_Sample.vb,.\[COLOR=red]s[/COLOR]cripts,16
I had even one further problem in that I used Install.txt instead of install.txt so until I fixed that I couldn't even get my plugin to install on Linux.
Originally posted by nfrobertson View PostRight. What I'm saying is in your install.txt, the last two lines look like:
NathanMark
HS3 Pro 4.2.19.5
Those directories I'm pointing to come right from the HS3 Linux tar distribution. I'm not sure how or why someone else would customize/change these from there? Once your next update is out I'll plan to test under Linux again. Just trying to help
Originally posted by mnsandler View Postmy plugin doesn't have native support for this device. if its doing what you need, then don't worry about the warning. Otherwise there is a custom plugin (search the forum) for this device that works with these devices
hurry4it writes a custom plugin for the EZFlora
http://store.homeseer.com/store/EZFl...HS3-P1676.aspx
http://board.homeseer.com/forumdisplay.php?f=1113HS 3.0.0.435 (PRO)
