Powerline Interface
    Powerline Interface
    Hi Mark,
    My system has been very stable for several months. Last night, it suddenly started to throw these messages in my Log file:
    Apr-03 8:30:00 PM Insteon Failed to program Default On Level
    Apr-03 8:30:00 PM Insteon Programming the Device 13.4C.DE with the new settings...
    Apr-03 8:30:00 PM Event Event Trigger "Centre Hall 2nd Floor - Evening Set 2"
    Apr-03 7:48:13 PM Device Control Device: Front Hall Keypad - Button B to On (100)
    Apr-03 7:48:13 PM Event Event Trigger "House Lights Startup - Trigger"
    Apr-03 7:15:00 PM Log Info The log database is currently 3.35MB in size.
    Apr-03 7:15:00 PM Log Maintenance 121 records, selected by date/time, were removed from the log database.
    Apr-03 7:11:04 PM Insteon The Interface could not be restarted. The plugin is being shutdown. Please restart HS.
    Apr-03 7:11:04 PM Insteon ..Could not contact Interface on COM3
    Apr-03 7:10:35 PM Insteon Attempting to restart the port and Interface...
    Apr-03 7:10:35 PM Insteon ..Could not contact Interface on COM3
    Apr-03 7:10:06 PM Insteon Attempting to restart the port and Interface...
    Apr-03 7:10:06 PM Insteon ..Could not contact Interface on COM3
    Apr-03 7:09:37 PM Insteon Attempting to restart the port and Interface...
    Apr-03 7:09:37 PM Insteon ..Could not contact Interface on COM3
    Apr-03 7:09:07 PM Insteon Attempting to restart the port and Interface...
    Apr-03 7:09:07 PM Insteon ..Could not contact Interface on COM3
    Apr-03 7:08:48 PM Insteon Attempting to restart the port and Interface...
    Apr-03 7:08:47 PM Insteon Failed to program Default On Level
    Apr-03 7:08:47 PM Insteon Warning! Communications lost. Attempting to restart the port...
    Apr-03 7:08:47 PM Insteon Transmit failed to device 2nd Floor Centre Hall Switch (13.4C.DE) for cmd 00 00 00 13 4C DE 1A 2E 00 01 06 80 00 00 00 00 00 00 00 00 00 00 00 after 5 tries.
    Apr-03 7:08:47 PM Insteon Interface_TrapError called from SendHex
    Apr-03 7:08:47 PM Insteon The RF PLM has failed to transmit the last 10 commands.
    Apr-03 7:08:29 PM Insteon Programming the Device 13.4C.DE with the new settings...
    Apr-03 7:08:29 PM Insteon Failed to program Default On Level
    Apr-03 7:08:29 PM Insteon Transmit failed to device 2nd Floor Centre Hall Switch (13.4C.DE) for cmd 00 00 00 13 4C DE 1A 2E 00 01 06 80 00 00 00 00 00 00 00 00 00 00 00 after 5 tries.
    Apr-03 7:08:13 PM Insteon Programming the Device 13.4C.DE with the new settings...
    Apr-03 7:08:13 PM Event Event Trigger "Centre Hall 2nd Floor - Evening Set 1"
    Apr-03 5:27:45 PM Insteon Motion Sensor 31.F0.FE settings read successfully.
    Apr-03 5:27:43 PM Insteon Received 31.F0.FE:2 (2nd Floor Motion Sensor - Dusk/Dawn Sensor) Go ON
    Apr-03 4:15:00 PM Log Info The log database is currently 3.35MB in size.
    Apr-03 4:15:00 PM Log Maintenance 156 records, selected by date/time, were removed from the log database.
    Apr-03 3:09:18 PM Event Event Trigger "Garage Door Close"
    Apr-03 3:09:18 PM Event Event Trigger "Garage Manual Close
    Now I look at my setup and it says that it cannot communicate with the powerline interface. I tried reinstalling the latest version of the CDM interface and restarting the system but nothing changed. Interface port is still set as COM3.
    Did my PLM suddenly die or has my PC blown a motherboard? Any thoughts?
    Brian
    Brian,
    please review the following post. it should help resolve the issue
    http://board.homeseer.com/showthread.php?t=154291#5
    Mark
    HS3 Pro 3.0.0.534
      Hi Mark,
      Thanks for the link. Sounds like I have some detective work to do. Strange that it was working yesterday morning but then suddenly crapped out. It also happened at a time when nobody was home so nothing should have changed that broke the connections.
      I will try to get things moving and let you know how I make out.
      Brian
        Mark
        Pretty sure that the problem is that my PLM is toast. The light on the side is dark. I tried to change the plug as well as press the reset button when I plug it in.
        pretty sure I need to order new unit. do you agree?
        brian
          Originally posted by brmeeke View Post
          Mark
          brian
          try a factory reset on the PLM (see the manual). if that doesn't help then yes the unit is toast.
          Mark
          HS3 Pro 3.0.0.534
