New KeypadLinc green set button LED question
    Hello,
    My new KeypadLinc dimmer has a green LED behind the set button. After pressing a button, this green LED flashes once. What does that indicate? Successful communication? Can this be disabled? I haven't been able to find anything about it in the manual or elsewhere.
    Thank you!
    HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
    what is the fw on this KPL? the flash might be either a transmit or a receive indicator.
    Mark
    HS3 Pro 3.0.0.534
      The plugin reports:
      Device Type: Dual-Band KeypadLinc Dimmer
      Firmware Version: 43
      It's a 2334-2xx
      I just discovered it's an acknowledgment indicator.
      http://cache.insteon.com/pdf/2334-2xx.pdf
      Page 15
      Blinks green once: One or more scene members acknowledge the button press.
      Blinks red once: One or more scene members did not acknowledge the button press (note: scene members may still have heard the scene command and adjusted their settings)
      It's not terrible, but it'd be nice if it could be disabled. The manual seems to indicate there is an 'Error Blink' flag that you could maybe program via your plugin, but I don't see anything regarding a 'Success Blink'.
        I'll check the dev notes and see what I can do
        Mark
        HS3 Pro 3.0.0.534
          Mike,
          i found the cmds for enabling/disabling this feature. look for this in the next version i post.
          the thing is, this feature is supposed to be disabled by default
          how did yours get enabled without software?
          Mark
          HS3 Pro 3.0.0.534
            - Just adding another data point -
            I also added a keypad with version 43 just last week. It too has the green LED turned on (fortunately, it hasn't blinked red yet). I certainly didn't do anything to turn it on. It's not a big issue to me, but I'd rather it was off too. (I'm on HS2 at plug-in version 2.0.0.15.)
              Ok, glad it's not just me. Either updated firmware changed default behavior or a batch of them were shipped with it on by accident?
