Insteon use
    Insteon use
    I currently bought the hometroller z because i was hoping to control my existing x10 and insteon products. I am disappointed because I don't feel the website was clear that i would need extra attachments or software. Can anyone gi eme the options to get x10 and insteon working for not too high a price?
    Rkshack
    if you use my insteon plugin, you can do x10 and insteon together with one controller like the PLM
    Mark
    HS3 Pro 3.0.0.534
      Can you post a link for the plm?
        PLM:
        http://www.smarthome.com/powerlinc-m...dual-band.html
        there is a usb version as well
        all that said, x10 via these controllers isn't the best.
        if you need serious x10 support, you should look for a dedicated x10 controller; there are several free x10 plugins. search for the plugins and find the compatible hw.
        Mark
        HS3 Pro 3.0.0.534
          I hate to be the bearer of bad news, but the Zee does not permit the installation of plug-ins other than the ones that HomeSeer sells with it -- z-wave, Insteon, and X-10. I.e., you cannot use third party plug-ins with the Zee.
            I understand from Rich, its really just a matter of building a dll plugin for the Zee. I haven't done this yet, but my Insteon plugin is Linux compatible, so i should be able to do this with a little guidance from Rich.
            Just trying to provide a little hope
            Mark
            HS3 Pro 3.0.0.534
              So as I understand your plug in is $59. That is a little expensive for me to not be sure it is going to work. If your plug in is not an option what devices will work with the homeseer default plug in.
                i think hst posted a list in the other forum for devices they support
                Mark
                HS3 Pro 3.0.0.534
                  So i found the plug in in the store. It says it is compatible with 2413u. So that should work for me if I use the built in plug in or would try to use yours correct?
                    Which other forum?
                      Which other forum?
                      http://board.homeseer.com/forumdisplay.php?f=1191
                      Mark
                      HS3 Pro 3.0.0.534
                        This post has a list of the supported devices
                        http://board.homeseer.com/showthread.php?t=166457
                        Chris
                          Guys,
                          quick update to close the loop
                          As mentioned, the current Zee doesn't support installing plugins. HST is working on a Zee S2 which will allow installing plugins like any other HS3 installation.
                          hope this helps.
                          Mark
                          HS3 Pro 3.0.0.534
                            2413u not workin
                            I can not seem to get my 2413u that I just bought to work. I have put a message in the forum but no replies as of yet. Any suggestions where I should look?
