Failed getting InterfaceStatus from Insteon - the interface was not found in
This topic is closed.
    Hi
    for the past few days the insteon plugin will stop working.
    i am moving my install to linux and get this after a few hours
    WARNING: Failed getting InterfaceStatus from Insteon - the interface was not found in the list of active interfaces, the list may need to be refreshed
    any idea?
    Do you have more than one USB device connected to the Linux hardware? There's an issue where this OS can "mix up" the USB ports causing this issue.
    -Rupp
      Its a raspberry pi 2 with no USB devices.
      And I am using the hub as a plm
        Here is the log.
        http://pastebin.com/RHpN1iaF
        i get a lot of errors and i am loosing connection to the hub.
        i restart homeseer and its back to normal.
        for example i see this alot:
        ed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2727: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2728: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2729: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2730: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2731: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2732: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2733: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2734: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2735: 5/1/2015 10:34:05 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52
        Line 2736: 5/1/2015 10:34:05 PM - Transmit failed to device Living Room 6 Button Keypad (24.EF.A8) for cmd 00 00 00 24 EF A8 1A 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 after 10 tries.
        Line 2738: 5/1/2015 10:34:05 PM - Failed to get remote link database record for Insteon device 24.EF.A8 record #19.
        Line 2773: 5/1/2015 10:34:14 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 0A 19 00
        Line 2774: 5/1/2015 10:34:14 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 0A 19 00
        Line 2775: 5/1/2015 10:34:14 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 0A 19 00
        Line 2776: 5/1/2015 10:34:14 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 0A 19 00
        Line 2777: 5/1/2015 10:34:14 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 0A 19 00
        Line 2778: 5/1/2015 10:34:14 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 0A 19 00
        Line 2779: 5/1/2015 10:34:14 PM - **Internal transmit attempt failed for CMD: 00 00 00 24 EF A8 0A 19 00
        Line 2780: 5/1/2015 10:34:14 PM - **Internal transmit attempt fail
          related to the following
          http://board.homeseer.com/showthread.php?t=174309
          Mark
          HS3 Pro 3.0.0.534
