I am trying out Mark's Insteon plug-in for the first time. All has been going well until I tried to add the 2852-222 Leak Sensor. I have two of them, and neither will add in. I get the error that the plug-in can't communicate with the device. These are older v1.0 Leak Sensors, so perhaps that is the issue. Is there any special way to add these devices?
Insteon Leak Sensor
Welcome,
try linking them to the plm first. put the plm into linking mode, and then put the sensor into linking mode.
then try manually registering them. remember the sensor must be in linking mode for the plugin to register them.Mark
HS3 Pro 3.0.0.534
Great. Glad you got it workingMark
HS3 Pro 3.0.0.534
