So i have a pair of LampLinc's in the living room. they worked fine via HS and locally. all of a sudden one of them, only ramps on and ramps off via HS. If i click on, it ramps on instead of instant on, if i click off, it ramps off instead of instant off. if click a dim level, it ramps to that level.
if i use local control, double tap works for instant on/off and single tap works for ramp on/off. the other lamplinc works perfectly fine from HS. on is on and off is off.
the settings in HS and in the plugin are exactly the same for both lamplinc's (default). not sure what to do at this point.
