X10 All Off Command
    X10 All Off Command
    Mark,
    Is it possible to send an "All Off" to a House Code with your HS 3 plugin?
    I'm using a mix of Insteon and X10 and really don't want to send out 12 OFF commands.
    I do not see it on any drop down menus.
    Doug
    Doug, if you have x10 enabled on the config page, there should be an insteon action to send these x10 cmds in version 3.0.5.18 or later
    Mark
    HS3 Pro 3.0.0.534
      X10 All Off Command
      Thanks for the quick reply - I am currently running with 3.0.4.8
      The 3.0.4.8 version is the version currently posted on the Homeseer HS3 "Plugins/Manage/Updates" link. Will you be updating that link or should I look elsewhere?
      Doug
        3.0.5.20 is avail in the HS Updater. you may need to fresh this; click Update Listing
        Mark
        HS3 Pro 3.0.0.534
          Mark - When I try to update to version 3.0.5.20 - I'm getting an error of "Fatal - Failed getting InterfaceStatus.. Interface not found in List of Active Interfaces"
          I am using the Insteon 2413U with Version 1.B software on the HS3 Pro Edition 3.0.0.96. This has worked for many months with your 3.0.4.8 software.
          Do you have any suggestions?
          Doug
            did the plugin update? if not, disable the plugin and then try the update. then restart hs
            Mark
            HS3 Pro 3.0.0.534
              I select for update and choose Download and Install.
              I get a Status of "Downloading Insteon" then "Installing Insteon" then "Install/Update of package Insteon Failed".
              All other update packages have installed properly including Vista Alarm.
              Thanks for your help,
              Doug
                did you disable the plugin first?
                you can install manually, see the following post
                http://forums.homeseer.com/showthread.php?t=173562
                it has install instructions
                Mark
                HS3 Pro 3.0.0.534
                  Yes I did disable the plugin first.
                  I will try installing manually but won't be able to get to it until next week.
                  Doug
