Any way to recover Insteon info from PIN?
    Hi,
    My HomeTroller crashed hard taking with it my backups. I know I should have copied the backups elsewhere but stupidly never did it.
    I've replaced it with a new HomeTroller S6 Pro. I see where I can display the links on the serial PIN but I was wondering if there might be a way to import the information into the Insteon databases in HomeSeer. The old HomeTroller was running HS2 and the new one is running HS3. I know that the human friendly labels won't be there but if the links can be imported, I can reenter the labels.
    If I can avoid relinking everything that would be wonderful since I've got well over 100 devices and that would be a pain.
    Thanks for any help!
    if you don't have an insteon.ini file you are going to need to at least re-register each device. the links are still stored in the devices and will be read and loaded back into the plugin.
    You won't need to relink devices.
    Mark
    HS3 Pro 3.0.0.534
      Okay, this is going to sound stupid - how do you just register a device? Where is the Insteon.ini file stored? If I can retrieve it from the old machine to the new one, will everything just "magically" work? Will this work with an ini from v2 on a v3 install?
        yes, any hs2 or hs3 insteon.ini will restore the devices into the hs database. you will need to recreate events. Put the insteon.ini into the \config folder and restart the plugin or hs
        if you can't find an insteon.ini you will need to register all the devices; use the Manage Device page from the plugin. Use the Add a New Device btn.
        Mark
        HS3 Pro 3.0.0.534
          Ok. I'll see if I can recover the ini. Thanks
