Hi Mark.
i had a HUB 1 for a long time and it started going crazy.
so i opened a RMA with insteon and bought in the meantime the HUB2.
i started to do the replacement using the option in your plugin and it managed to successfully replace only 5 out of 36
if i go into each of those which failed, i can see they have no master links to homeseer.
the problem is that when i reprogram them, the almost instantly fail to communicate (no Guns and roses pun attended ).
if i redo the reprogram around 15-60 times, it will eventually be able to reprogram.
once reprogram i have 1-2 hops communication and it is marked as excellent.
i am at it for around 12 hours and still have more than 25 devices to go.
any recommendations?
