MINI REMOTE
    MINI REMOTE
    MARK
    THE ATTACHED FILES ARE FROM THE PLUGIN FILES,MAYBE THEY WILL BE HELPFUL IN RESOLVING THE REMOTE PROBLEM IM HAVING
    the problem is the device has a new device type of "001B"
    i need to post a new plugin version to fix this.
    i should be able to do this tonight
    you will need to delete these devices from the plugin, and then do a factory reset to prepare for the new version
    Mark
    HS3 Pro 4.2.19.5
      MINI REMOTE
      THANKS MARK
      ILL LOOK FOR NEW VER.
        here you go
        to install"
        shutdown hs3
        make a backup of your hs database, insteon.ini and current plugin dlls.
        unzip the dlls to the homeseer root folder
        restart hs
        Mark
        HS3 Pro 4.2.19.5
          Everything went well until I installed my original remote and it did not recognize it .I did four factory resets but it didn't change (you'll see in attached file) Is there a fix?
            can you post the startup log from hs3? i want to make sure the new version is running
            device 34.FF.11 wasn't recognized. its still showing as 001B. i thought this was the new devicetype which i added.
            Mark
            HS3 Pro 4.2.19.5
              start up log this morning. im sure the new plug is working it loaded the new remote and showed it in device management.
                not sure if this will make a difference, but i didn't get the correct version of the insteon.dll in the previous zip. I have reposted a new zip above.
                please download and install the insteon.dll as you did before.
                it should be v1.5.0.22. you will see this listed in the startup log.
                aftert that, try the registration again
                Mark
                HS3 Pro 4.2.19.5
                  MARK
                  YOU'RE RIGHT IT DIDN'T MAKE ANY DIFFERENCE BUT IT PRODUCED THIS MESSAGE
                  Error in Background Update (DoJob #20): System.IndexOutOfRangeException: Index was outside the bounds of the array. at Insteon.Support.BackgroundUpdate.DoJob()
                  I BELIEVE THIS IS A HARDWARE ISSUE. TO THAT END I ORDERED ANOTHER REMOTE. I'LL TRY IT AND LET YOU KNOW. AS I EXPLAINED I DID USE A NEW REMOTE AFTER YOU SENT THE FIRST UPDATE AND IT WENT WELL. DO YOU THINK THIS ERROR WILL BE A PROBLEM?
                  PAT
                    ok. let us know the result of the new remote
                    Mark
                    HS3 Pro 4.2.19.5
                      MINI REMOTE
                      MARK
                      INSTALLED NEW REMOTE WORKS FINE.
                      I DROPPED BACK TO v1.5.0.20. FOR THE INSTALL. 22 KEEP SHOWING THE ERROR I SENT IN PRIOR REPLY.
                      ITS THE HARDWARE .
                        sounds good. if you can provide any additional info (ie detailed logs) on the prev error, i'll take a look.
                        Mark
                        HS3 Pro 4.2.19.5
                          This is the error I was refering too. This would appear as it when the registration process was happening. This only happened with ver. .22 it did not happen with ver. .20
                            can you post a few additional log entries that led up to this? you should be able to find them in aa config\insteon error report.log file
                            Mark
                            HS3 Pro 4.2.19.5
                              ERROR LOGS
                              MARK
                              THE LOGS ARE TO LARGE TO SEND AS A POST . DO YOU HAVE ANOTHER WAY TO GET THEM
