Trouble Getting X10 Commands Sent
  • mnsandler
    well i don't see the startup msgs, but i do see msgs of the plugin sending x10 cmds to the plm and the plm responding; so that is good.
    so i would suggest moving an x10 device closer to the plm and see if the x10 module responds.
  • bilesb
    Log results
    The following is my log results. I see no showing of statement of initializing X10.
    Thanks Mark for looking at this.
    Bruce
    6/11/2015
    Jun-11 1:59:13 PM Startup Settings Loaded.
    Jun-11 1:59:13 PM Startup ************************************************************ ********************
    Jun-11 1:59:13 PM Startup HomeSeer version 3.0.0.181 Edition: HS3 Standard Starting Now
    Jun-11 1:59:13 PM Startup Creating Class Objects...
    Jun-11 1:59:13 PM Startup COM port classes started.
    Jun-11 1:59:13 PM Startup Application interface class started.
    Jun-11 1:59:13 PM Startup Web server class started.
    Jun-11 1:59:13 PM Startup E-Mail SEND class started.
    Jun-11 1:59:13 PM Startup E-Mail RECEIVE class started.
    Jun-11 1:59:13 PM Startup Plug-In Interface class started.
    Jun-11 1:59:13 PM Startup HSPhone external interface class started.
    Jun-11 1:59:13 PM Startup Local voice recognition class started.
    Jun-11 1:59:13 PM Startup Database SAVE process started.
    Jun-11 1:59:13 PM Startup Loading configuration file ...
    Jun-11 1:59:13 PM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData-2015-06-08.hsd
    Jun-11 1:59:13 PM Database Loading Devices...
    Jun-11 1:59:13 PM Load Config 193 total devices loaded.
    Jun-11 1:59:13 PM Load Config Loading Event Groups...
    Jun-11 1:59:13 PM Load Config Loading Events...
    Jun-11 1:59:13 PM Load Config 78 total events loaded.
    Jun-11 1:59:13 PM Load Config Loading COUNTERS...
    Jun-11 1:59:13 PM Load Config Loading TIMERS...
    Jun-11 1:59:13 PM Startup HomeSeer version is: 3.0.0.181
    Jun-11 1:59:13 PM Startup Creating Speaker Client Interface Object...
    Jun-11 1:59:13 PM Startup This version of HomeSeer is registered as a HS3STANDARD version.
    Jun-11 1:59:16 PM Info Remote plug-in API interface started on port 10400
    Jun-11 1:59:16 PM Startup Checking for available plug-ins
    Jun-11 1:59:16 PM Plug-In Found plug-in: HSTouch Server, version: 3.0.0.68
    Jun-11 1:59:16 PM Plug-In Found plug-in: Insteon, version: 3.0.5.20
    Jun-11 1:59:16 PM Plug-In Found plug-in: SimpleHomeNet, version: 2.0.0.0
    Jun-11 1:59:16 PM Startup Initializing Plug-Ins
    Jun-11 1:59:16 PM Info Plugin HSTouch Server has connected. IP:127.0.0.1:62884
    Jun-11 1:59:17 PM Plug-In Finished initializing plug-in HSTouch Server
    Jun-11 1:59:17 PM Info Plugin Insteon has connected. IP:127.0.0.1:62886
    Jun-11 1:59:17 PM Insteon Insteon Support library (Insteon.dll) version: 1.0.5.20
    Jun-11 1:59:18 PM Insteon RF PLM contacted on COM3 with an Insteon address of 2B.91.E1 and firmware version 9B
    Jun-11 1:59:22 PM Insteon Waiting to initialize External Devices...
    Jun-11 1:59:22 PM Plug-In Finished initializing plug-in Insteon
    Jun-11 1:59:22 PM Info Plugin SimpleHomeNet has connected. IP:127.0.0.1:62889
    Jun-11 1:59:22 PM SimpleHomeNet InitIO called, plug-in is being initialized...
    Jun-11 1:59:22 PM Plug-In Finished initializing plug-in SimpleHomeNet
    Jun-11 1:59:22 PM Web Server Local IP address (subnet) is: 192.168.0.19 (255.255.255.0)
    Jun-11 1:59:22 PM Web Server UPNP Discovery started
    Jun-11 1:59:22 PM Web Server Web Server started on port 80
    Jun-11 1:59:24 PM Startup Creating ASP.NET application host...
    Jun-11 1:59:25 PM Startup Start automation engine...
    Jun-11 1:59:25 PM Startup Initializing Speaker Client Interface
    Jun-11 1:59:25 PM Speech Listening for remote speaker connections on port 10401
    Jun-11 1:59:25 PM Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
    Jun-11 1:59:25 PM Startup Updater services starting...
    Jun-11 1:59:25 PM Startup Starting DDNS service...
    Jun-11 1:59:25 PM HSTouch Server Server started on port 10200
    Jun-11 1:59:25 PM Startup Running the startup script Startup.vb
    Jun-11 1:59:25 PM Insteon External Device Registration complete.
    Jun-11 1:59:26 PM Startup Starting Event Scheduler...
    Jun-11 1:59:26 PM Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
    Jun-11 1:59:26 PM Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
    Jun-11 1:59:26 PM Startup HSSentry is disabled in Setup, sentry will not be started.
    Jun-11 1:59:26 PM Startup Start up complete.
    Jun-11 1:59:26 PM Info System connected to MyHomeSeer Service, waiting for acknowledge...
    Jun-11 1:59:26 PM Info System connected to MyHomeSeer Service successfully.
    Jun-11 1:59:26 PM Insteon External device name 28.AB.98 (Address:28.AB.98) has registered as external device #1
    Jun-11 1:59:28 PM Web Server Web Server authorized local login successful from: 192.168.0.19 User: brucebiles@cox.net
    Jun-11 1:59:57 PM TTS Speak ():Welcome to Home-Seer
    Jun-11 2:00:02 PM Speaker Speaker host added, Name: BILES-HP Instance: Default IP address: 127.0.0.1
    Jun-11 2:02:18 PM Insteon Starting Scheduled Polling...
    Jun-11 2:02:25 PM Device Control Device: Library Appliance Module for Testing to On (100) by/from: CAPI Control Handler
    Jun-11 2:02:25 PM Insteon CAPIControl: Label=On, Value=100, ControlType=Button
    Jun-11 2:02:25 PM Insteon Immediate Send X10 Command: B8 Cmd:2 Pcnt:100 Data1: 0 Data2:0
    Jun-11 2:02:25 PM Insteon Sending command 02 63 ED 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    Jun-11 2:02:25 PM Insteon ..Got RF PLM Response 02 63 ED 00 06
    Jun-11 2:02:25 PM Insteon Sending command 02 63 E2 80 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    Jun-11 2:02:25 PM Insteon ..Got RF PLM Response 02 63 E2 80 06
    Jun-11 2:02:30 PM Device Control Device: Library Appliance Module for Testing to Off (0) by/from: CAPI Control Handler
    Jun-11 2:02:30 PM Insteon CAPIControl: Label=Off, Value=0, ControlType=Button
    Jun-11 2:02:30 PM Insteon Immediate Send X10 Command: B8 Cmd:3 Pcnt:0 Data1: 0 Data2:0
    Jun-11 2:02:30 PM Insteon Sending command 02 63 ED 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    Jun-11 2:02:30 PM Insteon ..Got RF PLM Response 02 63 ED 00 06
    Jun-11 2:02:31 PM Insteon Sending command 02 63 E3 80 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    Jun-11 2:02:31 PM Insteon ..Got RF PLM Response 02 63 E3 80 06
    Jun-11 2:02:33 PM Insteon Starting Scheduled Polling...
    Jun-11 2:02:48 PM Insteon Starting Scheduled Polling...
  • mnsandler
    this is all insteon traffic
    x10 msgs have the following outbound format
    02 63 XX YY
    can you check the hs startup log and see if the x10 protocol is initialized
    try pressing an on/off btn associated with appliance module
  • bilesb
    started a topic Trouble Getting X10 Commands Sent
    I am having trouble send or receiving x10 commands. I am running HS3 3.0.0.181, HSTouch 3.0.0.68, and Insteon 3.0.5.20, and SimpleHomeNet 2.0.0.0. When using an X10 controller the Appliance Module (AM466) works fine. It's Code is B8. It hasn't worked for at least a couple of years but now I have need of using a few X10 devices in addition to about 70 Insteon individual devices.
    I turned on detailed logging and received the following and using the Tools/Control Panel I am sending an on and off command to a x10 appliance module. It never changes state. I have the Insteon config set for "Enable X10" and I clicked on "Update X10 Devices". What else must I do?
    Jun-11 9:19:55 AM Insteon Starting Scheduled Polling...
    Jun-11 9:19:55 AM Insteon Timed poll for Insteon device Workshop Light (23.F3.7F), Last contact 6/11/2015 8:59:40 AM. Polling interval of 20 min. reached, polling...
    Jun-11 9:19:55 AM Insteon Requesting Insteon status (Polling) for device Workshop Light (23.F3.7F)
    Jun-11 9:19:55 AM Insteon Attempting to update the status for Workshop Light (23.F3.7F)
    Jun-11 9:19:55 AM Insteon Sending command 02 62 23 F3 7F 0A 19 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    Jun-11 9:19:55 AM Insteon ..Got RF PLM Response 02 62 23 F3 7F 0A 19 00 06
    Jun-11 9:19:57 AM Insteon Received STX 0x50 (Raw Insteon Rec):23 F3 7F 2B 91 E1 23 04 00
    Jun-11 9:19:57 AM Insteon [CheckDeltas] Database recently heard delta value for device 23.F3.7F is current.
    Jun-11 9:19:57 AM Insteon Database delta value of 4 for device 23.F3.7F is current. No changes since last database update.
    Jun-11 9:19:57 AM Insteon Received message from Workshop Light (23.F3.7F) taking hops: 3
    Jun-11 9:19:57 AM Insteon StandardDeviceClass ProcessStatus called with Level:0
    Jun-11 9:19:57 AM Insteon Received a Direct ACK from Workshop Light (23.F3.7F)
    Jun-11 9:19:57 AM Insteon Setting status and value for device 23.F3.7F:1. Old status:0 Old Value:0, New Status:3 New Value:0
    Jun-11 9:19:57 AM Insteon Received STX 0x50 (Raw Insteon Rec):23 F3 7F 2B 91 E1 23 04 00 Debouncing repeat.
    Jun-11 9:19:58 AM Insteon ..Finished Scheduled Polling for 1 devices.
    Jun-11 9:20:10 AM Insteon Starting Scheduled Polling...
    Bruce
    Last edited by bilesb; June 11, 2015, 09:33 AM. Reason: Forgot to mention I have a 2413U Rev 1.B
