Still using Homeseer 2 what is the latest version
    Mark:
    I am using both Homeseer 2 and 3. I haven't switched over to HS3 yet. One of my Keypads went bad and had to replace it. It is Version 2487S Revision 6.9. I am using 2.0.0.9 on Homeseer 2. I am using HS version 2.5.0.78.
    Is 2.0.0.9 the latest version? Also, If I need to buy anymore Keypadlincs, will the later versions still work with this (HS2) plugin?
    Steve
    2.0.0.15 beta is in the forum. You can see the changes on the following thread. The plugins (hs2 & hs3) both support the same set of devices (including KPLs)
    http://board.homeseer.com/showthread.php?t=169304
    if you have any problems after upgrading or registering a new device, just let me know. I don't anticipate any problems.
    Mark
    HS3 Pro 3.0.0.534
      Thanks, I will try it out.
      Steve
        as always, make a backup of everything (insteon.ini and homeseer db at a minimum)
        Mark
        HS3 Pro 3.0.0.534
