Hi Mark
I have a few Hidden Door sensors (2845-222). Everything works great except the low Battery Warning and the Batter Voltage.
Once the Low Battery warning is set there is no way for me to reset/clear it in the GUI. I have to use a script to manually reset the value. Could you add a reset button like you have for the Motion sensor? I could not work out any other way of clearing the Low Battery. Once the device has had the battery replaced it just stops sending the Low Battery, it never sends a clear.
For the battery level there is no way to query it again after the device is added. Does this device support querying the battery after an event like the motion sensor? The battery voltage is pretty useless currently since it never updates.
