FanLinc and 2413S
    FanLinc and 2413S
    I installed a FanLinc in an upstairs bedroom and I have a 2413S.
    Both devices are dual-band and both are on separate parts of my electrical service. I thought both devices being dual-band would allow them to communicate but I can't get the FanLinc added by its device id or the tap search method. Am I misunderstanding dual-band?
    The RF signals often do not travel very far. This will be especially true if your fanlinc is behind a metal cover at the top of the fan. Your Insteon network will work much better if you add a 240V phase coupling device. Also, the more Insteon (particularly dual band) devices that you add, the better it will get.
      you should have at least one dual-band device on each leg to begin with or a phase coupler at the panel.
      i would add an access point between the two locations as well
      Mark
      HS3 Pro 3.0.0.534
        Ok, so I have the following installed:
        1) Smarthome 2443 Access Point I
        2) Insteon 2406H SignaLinc
        3) Insteon 2334-232 Keypad Dimmer Switch
        I'm finding that there's a delay on lights lighting. As I look at my registered devices, my FanLinc has a high failure rate for cmds
        I've attached a screenshot of my devices:
          The 44% would account for the delay. the plugin will retry based on your settings and usually get the job done but at the expense of time.
          noise is the cause of this problem; from where is the difficult question to answer
          if you are using fluorescent bulbs in the fan, try LEDs and see if the delay is eliminated.
          Mark
          HS3 Pro 3.0.0.534
            I do have LEDs in the fan. The keypad is literally 6 feet away from the FanLinc. Would it help to put the wireless access point closer to the FanLinc?
              How about some checks to narrow things down. Do the comms test with both the light and the fan off. Does it do a lot better that way?
              If so, repeat with just the fan on and just the light on. Does having one or the other on make the failures go way up? If so that is the source of the noise.
              If it's still bad with the fan and light off, try turning off and unplugging as much other stuff as is reasonable. See if you can narrow it down to one or two problem devices.
              Is this bedroom fed by an arc-fault breaker?
                I'm not sure what a "comms test" is?
                  comm test is a function on the manage device page, or a specific device page
                  Mark
                  HS3 Pro 3.0.0.534
                    Thanks, this doesn't look like good news?
                    The Master Bedroom New Lamp Module is actually the FanLinc, need a better name
                      if the fanlinc is inside a metal fan cowl, the RF signal might not be very strong. but try moving the Accesspoint to different locations, even in a room above the fanlinc. try putting the access point on the same circuit as the fanlinc.
                      when you only have a few insteon devices, the signal isn't as strong as when you have the devices installed all over.
                      Mark
                      HS3 Pro 3.0.0.534
                        No, the FanLinc is outside the metal fan cowl. The Access Point should be on the same circuit but I'll move it closer to the FanLinc
                          was the fan running when you did the comm tests? if so, try again with the fan off and see of the stats are the same or different. compare stats with fan on vs fan off
                          Mark
                          HS3 Pro 3.0.0.534
                            neither the fan nor the lights ran when I did the test
                            strangely, I can control the fan now through the plugin, the light never comes on. should I delete the FanLinc device and re-add it now?
                              lets try this, run a long extension cord from the plm to an outlet on the same circuit as the fan, then retest the control and comm test.
                              if you can't control the light, then try the 'program device for homeseer' btn on the device edit page within the plugin. maybe a link is bad. Otherwise, yes, delete the device from the plugin, factory reset it (see manual) and then register it again.
                              Mark
                              HS3 Pro 3.0.0.534
