Had to re-configure smoke bridge
    So, we decided to test the smoke alarms today, and the smoke bridge had stopped communicating with homeseer.
    When I tested the alarms, the light on the smoke bridge flashed red.
    It did still contain the links to talk to the PLM.
    I had detailed logging on and NOTHING appeared for it in the log.
    I had to actually remove the device and re-add it to homeseer (which made me need to re-configure some events, I'm using things like $$DSR:xxx:
    Which brings me to this question: Is there any way I can identify insteon devices by their address, rather than the device ID that homeseer/the plugin assigns? That ID changes if I have to remove and re-add a device.
    refer to devices by name. you have control of this.
    Mark
    HS3 Pro 3.0.0.534
      Ah! I didn't know I could do that. What's the token replacement for that?
        well i don't see by name reference.
        did you try
        $$DTA : ( address ) :
        address should be the insteon id as identified as AA.BB.CC:1
        Mark
        HS3 Pro 3.0.0.534
          It seems to interpret that as:
          Device not found1:
          Which means to me that the colon in the device address is throwing it off.
            What I've done for now is assigned the device a code and I'm using $$DSC. That way, if I have to re-do the device, I won't have to touch any events.
            Mark, I'm wondering if the colon in the device address could be changed to a different character?
              I can't change the colon. i can submit this as a bug to HST. can you give me an example of what you are trying to do that's not working
              adding a 'code' changes the address field which will cause plugin problems
              Mark
              HS3 Pro 3.0.0.534
