So I am trying to figure out how do do a config where I have two overhead lights using Inlinelinc's with two keypadlincs to control them.
Unfortunately I have a mix of versions with an older KPL with a new one, and an older Ininelinc with a new one.....
I have a number of challenges because I want the ON/Load on the KPLs to switch both lights and I want button A and button B to control the lights independently.
I would like HomeSeer to be able to control the whole system
I want the switches and lights to operate as independently as possible and not rely on the PLM or HS for local operation. I want everything to stay in sync and to be able to hide what all the bits and pieces so the HSTouch client is simple to use.
So lets talk about the first challenge(there will be more!)
I want to link the On/Load button to button A and Button B.
I can not create this link in HS but I can create it locally on the switch. IF I do create it locally it works locally but it does not appear in HS when I update links on the Keypad Linc.
If I switch the lights on in HS by using HS to control the ON/LOAD button it works and the inline lincs turn on but button A and Button B do not.
What do you think.
What do you think.
