Can Insteon PLM be used as primary X10 controler for Homeseer if yes is there any config necessary.
PLM X10 CONTROL
short answer, Yes,
with hs3, you need to enable the x10 option on the plugin config page, and then restart hsMark
HS3 Pro 3.0.0.534
are you seeing x10 msgs being transmitted when you have detailed logging enabled?
please post your startup log and a log snippet of an x10 device being controlled from the dev mgmt pageMark
HS3 Pro 3.0.0.534
Originally posted by Gallina View PostNo x10 messages in log . In device management a device will not react. If I tap a command (on or Off) it does not react. Attached is startup logMark
HS3 Pro 3.0.0.534
looks like you are using the hub not a plm. some are reporting that x10 doesn't work with the hub.
please enable detailed logging on the plugin config page and attempt an x10 control, and check the log againMark
HS3 Pro 3.0.0.534
the startup log looks good.
please verify the following on any x10 hs device you created:
Interface = Insteon
Device Type (String) = Insteon X10
these are found on the Advanced tabMark
HS3 Pro 3.0.0.534
I now understand the problem. X10 is different in HS3. x10 devices are now specific to a plugin. Since your existing devices were created with a different plugin, i can't control them.
lets try the following:
run the "Update X10 Devices" function on my plugin config page so the plugin will take ownership of your x10 devices.
if this doesn't help, you will need to recreate your x10 devices (A1, A2, B1, etc) via the Insteon X10 tab on the Add Device pageMark
HS3 Pro 3.0.0.534
Originally posted by Gallina View PostMark,
I tried the update procedure didn't work. I did re-entered a device as insteon and it worked. I don't have that many x10 (14) it shouldn't take long
Thanks again
PatMark
HS3 Pro 3.0.0.534
