Unable to set com port for Insteon plug-in
This topic is closed.
    I have a HometrollerZee S2 with a 2413U. I can not set the com port for Mark's Insteon plug. I have the HSInsteon Plug-in and it works fine with the 2413U. I tried using the same com port on Mark's plug-in but it does not work. I also tried com 1, 2 etc. Uninstalled, reinstalled, rebooted (several times) no luck. I have attached a snapshot of the installed plug-ins.
    Thanks for any help.
    Chuck Houston
    Chuck, disable the hsinsteon plugin, and enable mine and then goto the config page (click Insteon on the above screen) and set the port. it should work. others have it working with linux without issue
    Mark
    HS3 Pro 4.2.19.5
      see the above response
      Mark
      HS3 Pro 4.2.19.5
        Still unable to connect to PLM
        Mark
        I'm sorry to say it is not working. I uninstalled both plugins, rebooted. Reinstalled your's, set the port to /dev/tty/USB0, then COM1, COM2 etc. with reboots in between. Still no luck. You say others are using the Zee S2 just fine with 2413U, what port are they using? Any idea what I am doing wrong? I really want to like your plug-in but...
          can you post your config/insteon.ini file so i can review your settings
          port name /dev/ttyUSB0 is the only thing i think will work from linux
          Mark
          HS3 Pro 4.2.19.5
            Mark, I do not know how to get the file from the ZEE S2 to my pc to post it. I have putty and know a little Unix.
              you can just copy and paste the contents to a post. i don't need the actual file
              Mark
              HS3 Pro 4.2.19.5
                I think I got it
                I have attached the Insteon.ini
                I fixed it!! /dev/ttyUSB0 NOT /dev/tty/USB0. Looking at the log and your previous reply it finally jumped out at me. Thanks for the help and on to the fun stuff.
