Replacing a KeypadLinc
    There's some kind of substation upgrade going on here and apparently today's brief power interruption was one too many for one of my KeypadLincs. (It has locked up each time which is about once a day for the last several days. Today, it won't recover.) It's configured as eight buttons and is a KeypadLinc V2 Dimmer, Firmware Version: 2D. I've ordered a replacement that will probably be Dual-Band KeypadLinc Dimmer, Firmware Version: 43.
    I am still on HS2. What is the least painful way to do this replacement? Is there any way to keep the same house and device codes for each of the keys?
    there is a 'replace this device' btn on the exsting device edit page within the plugin.
    Very important: Do not delete the exsting device from the plugin!. just click he 'replace this device' and following the instructions on the next page.
    Mark
    HS3 Pro 3.0.0.534
      Thanks. I'll try it when the new switch gets here.
        So, it looks like a factory reset may have the old keypadlinc working again. I changed it back from the default 6 button configuration to 8 buttons, but now I am at a loss as to how to reprogram the 60 or so links into it.
        I tried edit device links, but all it does is offer to let me delete the links (that are already out of the device anyway).
        It does say this "WARNING: Deleting links can cause devices to function improperly. Using the 'Reprogram links' and 'Reprogram group' options in the device and group edit page will restore the links that are managed by this plug-in, but NOT OTHER LINKS, SUCH AS THOSE CREATED MANUALLY BY TAP-LINKING DEVICES!"
        "Reprogram links" sounds like exactly what I need, but I can't seem to find it anywhere. I have HS2 with Plug-In v2.0.0.15.
          there is no way to reprogram the device links from the existing links on the screen.
          you should print the links screen for reference. then read the links which will clear all the links. then 'program device for homeseer', then add your links.
          Mark
          HS3 Pro 3.0.0.534
            I think I'll just wait for the new switch then. That sounds less painful, assuming that replace-device will copy the links on the screen into the new keypad.
              Okay, I have the new keypadlinc, and it's not going so well. When I try replace device, it ends with this:
              Your system could not be reprogrammed. Program And Replace Device - The destination device could not be programmed, function aborted before system/device changes were made.
              The Log is as follows:
              7/18/2015 1:29:45 PM Insteon Edit Insteon Device #17 Addr: 0E.1F.DE, Name:Keypad, Location:Master Bedroom
              7/18/2015 1:29:48 PM Insteon Starting Scheduled Polling...
              7/18/2015 1:29:48 PM Insteon ..Finished Scheduled Polling for 0 devices.
              7/18/2015 1:29:56 PM Insteon Replace Device Selected
              7/18/2015 1:29:56 PM Insteon In Replace - Device #17 Addr: 0E.1F.DE, Name:Keypad, Location:Master Bedroom
              7/18/2015 1:30:03 PM Insteon Starting Scheduled Polling...
              7/18/2015 1:30:03 PM Insteon ..Finished Scheduled Polling for 0 devices.
              7/18/2015 1:30:35 PM Insteon Replace Device Confirmation Selected
              7/18/2015 1:30:35 PM Insteon Launching new BackgroundUpdate Thread with job type 10...
              7/18/2015 1:30:35 PM Insteon In BackgroundUpdate Thread...
              7/18/2015 1:30:35 PM Insteon Calling AddRecord for 34.DD.44 1 True
              7/18/2015 1:30:35 PM Insteon Sending command 02 6F 41 A2 01 34 DD 44 00 00 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True
              7/18/2015 1:30:35 PM Insteon ..Got RF PLM Response 02 6F 41 A2 01 34 DD 44 00 00 00 15
              7/18/2015 1:30:35 PM Insteon Sending Insteon ID Broadcast for '34.DD.44'
              7/18/2015 1:30:35 PM Insteon Sending command 02 62 34 DD 44 0F 10 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:36 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 10 00 06
              7/18/2015 1:30:36 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 A7 10 FF
              7/18/2015 1:30:36 PM Insteon Got i2cs type broadcast for Insteon ID 34.DD.44 Need to link device to RF PLM now...
              7/18/2015 1:30:36 PM Insteon Attempting to link the i2cs device 34.DD.44 to the RF PLM
              7/18/2015 1:30:36 PM Insteon Sending command 02 64 01 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:36 PM Insteon ..Got RF PLM Response 02 64 01 00 06
              7/18/2015 1:30:36 PM Insteon Sending command 02 62 34 DD 44 1F 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:36 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 06
              7/18/2015 1:30:38 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 09 00
              7/18/2015 1:30:38 PM Insteon Received a Direct ACK from 34.DD.44
              7/18/2015 1:30:38 PM Insteon PLM_ProcessInBuffer received STX 0x53, but the command payload is incomplete, waiting..
              ..................... This same line 154 more times ...............................................
              7/18/2015 1:30:39 PM Insteon PLM_ProcessInBuffer received STX 0x53, but the command payload is incomplete, waiting..
              7/18/2015 1:30:39 PM Insteon PLM_ProcessInBuffer received STX 0x53 (Link Completed):01 00 34 DD 44 01 41 44
              7/18/2015 1:30:39 PM Insteon Sending command 02 62 34 DD 44 1F 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:39 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 06
              7/18/2015 1:30:40 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 09 00
              7/18/2015 1:30:40 PM Insteon Received a Direct ACK from 34.DD.44
              7/18/2015 1:30:40 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 01 41 44 8B 01 76
              7/18/2015 1:30:40 PM Insteon Got i2cs type broadcast for Insteon ID 34.DD.44 of type , Firmware version
              7/18/2015 1:30:40 PM Insteon Sending command 02 62 34 DD 44 0F 08 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:40 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 08 00 06
              7/18/2015 1:30:41 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 08 00
              7/18/2015 1:30:41 PM Insteon Pass 1, updating devices that appear to have stale link tables...RF devices are ignored...
              7/18/2015 1:30:41 PM Insteon Pass 2, Now attempting to reprogram your system for the replacement device...
              7/18/2015 1:30:41 PM Insteon Calling AddRecord for 34.DD.44 1 True
              7/18/2015 1:30:41 PM Insteon Sending command 02 6F 41 A2 01 34 DD 44 00 00 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True
              7/18/2015 1:30:41 PM Insteon Received a Direct ACK from 34.DD.44
              7/18/2015 1:30:41 PM Insteon ..Got RF PLM Response 02 6F 41 A2 01 34 DD 44 00 00 00 15
              7/18/2015 1:30:41 PM Insteon Sending Insteon ID Broadcast for '34.DD.44'
              7/18/2015 1:30:41 PM Insteon Sending command 02 62 34 DD 44 0F 10 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:41 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 10 00 06
              7/18/2015 1:30:41 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 10 00
              7/18/2015 1:30:42 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 01 41 44 8B 01 76
              7/18/2015 1:30:42 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 01 41 44 8B 01 76 Debouncing repeat.
              7/18/2015 1:30:42 PM Insteon Got controller/responder type broadcast for Insteon ID 34.DD.44 of type 0141, Firmware version 44
              7/18/2015 1:30:42 PM Insteon Program And Replace Device - Process starting... (0E.1F.DE-34.DD.44)...
              7/18/2015 1:30:42 PM Insteon Step 1 of 5: Programming new device with links...
              7/18/2015 1:30:42 PM Insteon GetInsteonProtocol for '34.DD.44'
              7/18/2015 1:30:42 PM Insteon Sending command 02 62 34 DD 44 0F 0D 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:42 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 0D 00 06
              7/18/2015 1:30:42 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 0D 02
              7/18/2015 1:30:42 PM Insteon Received a Direct ACK from 34.DD.44
              7/18/2015 1:30:42 PM Insteon Got Insteon Protocol Engine response from Insteon ID 34.DD.44, Protocol i2CS
              7/18/2015 1:30:42 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F FF 08 E2 01 1C F5 09 FF 1F 01 9D to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:42 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F FF 08 E2 01 1C F5 09 FF 1F 01 9D 06
              7/18/2015 1:30:44 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 2F 00
              7/18/2015 1:30:44 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F F7 08 E2 02 1C F5 09 FF 1F 02 A3 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:44 PM Insteon Received a Direct ACK from 34.DD.44
              7/18/2015 1:30:44 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F F7 08 E2 02 1C F5 09 FF 1F 02 A3 06
              7/18/2015 1:30:44 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00 Debouncing repeat.
              7/18/2015 1:30:47 PM Insteon Did not receive a response from (34.DD.44). Try #1 failed.
              7/18/2015 1:30:47 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F F7 08 E2 02 1C F5 09 FF 1F 02 A3 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:47 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F F7 08 E2 02 1C F5 09 FF 1F 02 A3 06
              7/18/2015 1:30:47 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 2F 00
              7/18/2015 1:30:47 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:47 PM Insteon Received a Direct ACK from 34.DD.44
              7/18/2015 1:30:48 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 06
              7/18/2015 1:30:48 PM Insteon Starting Scheduled Polling...
              7/18/2015 1:30:48 PM Insteon ..Finished Scheduled Polling for 0 devices.
              7/18/2015 1:30:48 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 2F 00 Debouncing repeat.
              7/18/2015 1:30:51 PM Insteon Did not receive a response from (34.DD.44). Try #1 failed.
              7/18/2015 1:30:51 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:51 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 06
              7/18/2015 1:30:51 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 AB 2F FF
              7/18/2015 1:30:53 PM Insteon Did not receive a response from (34.DD.44). Try #2 failed.
              7/18/2015 1:30:53 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:53 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 06
              7/18/2015 1:30:54 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 AB 2F FF
              7/18/2015 1:30:56 PM Insteon Did not receive a response from (34.DD.44). Try #3 failed.
              7/18/2015 1:30:56 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:56 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 06
              7/18/2015 1:30:56 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 AB 2F FF
              7/18/2015 1:30:58 PM Insteon Did not receive a response from (34.DD.44). Try #4 failed.
              7/18/2015 1:30:58 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
              7/18/2015 1:30:58 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 06
              7/18/2015 1:30:59 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 A7 2F FF
              7/18/2015 1:31:01 PM Insteon Did not receive a response from (34.DD.44). Try #5 failed.
              7/18/2015 1:31:01 PM Insteon Program And Replace Device - The destination device could not be programmed, function aborted before system/device changes were made.
              7/18/2015 1:31:01 PM Insteon Your system could not be reprogrammed.Program And Replace Device - The destination device could not be programmed, function aborted before system/device changes were made.
              7/18/2015 1:31:01 PM Insteon Replace device routine complete.
              7/18/2015 1:31:01 PM Insteon BackgroundUpdate Thread Complete...
              7/18/2015 1:31:03 PM Insteon Starting Scheduled Polling...
              7/18/2015 1:31:03 PM Insteon ..Finished Scheduled Polling for 0 devices.
              7/18/2015 1:31:14 PM Insteon Received STX 0x50 (Raw Insteon Rec):27 8D 33 00 00 02 CB 13 02
              7/18/2015 1:31:14 PM Insteon Received message from 1st Kitchen Motion Sensor (27.8D.33) taking hops: 1
              7/18/2015 1:31:14 PM Insteon ProcessGroupBroadcast: Device 1st Kitchen Motion Sensor Dusk/Dawn Sensor: (27.8D.33) is group broadcast source (tgt group/button:2) sending cmd 13
              7/18/2015 1:31:14 PM Insteon Setting status and value for device [96. Old status:2 Old Value:100, New Status:3 New Value:0
              7/18/2015 1:31:15 PM Insteon Received STX 0x50 (Raw Insteon Rec):27 8D 33 00 00 02 CB 13 02 Debouncing repeat.
              7/18/2015 1:31:15 PM Insteon Received STX 0x50 (Raw Insteon Rec):27 8D 33 00 01 02 CB 13 02
              7/18/2015 1:31:15 PM Insteon Received message from 1st Kitchen Motion Sensor (27.8D.33) taking hops: 1
              7/18/2015 1:31:15 PM Insteon Received STX 0x50 (Raw Insteon Rec):27 8D 33 13 00 02 CB 06 00
              7/18/2015 1:31:15 PM Insteon Received STX 0x50 (Raw Insteon Rec):27 8D 33 13 00 02 CB 06 00 Debouncing repeat.
              7/18/2015 1:31:18 PM Insteon Starting Scheduled Polling...
              7/18/2015 1:31:18 PM Insteon ..Finished Scheduled Polling for 0 devices.
              7/18/2015 1:31:34 PM Insteon Received STX 0x50 (Raw Insteon Rec):36 FE F1 00 00 04 CB 11 04
              7/18/2015 1:31:34 PM Insteon Received message from HVAC Stage2 (36.FE.F1) taking hops: 1
              7/18/2015 1:31:34 PM Insteon Received STX 0x50 (Raw Insteon Rec):36 FE F1 00 00 04 CB 11 04 Debouncing repeat.
              7/18/2015 1:31:35 PM Insteon Received STX 0x50 (Raw Insteon Rec):36 FE F1 11 00 04 CB 06 00
              7/18/2015 1:31:35 PM Insteon Received message from HVAC Stage2 (36.FE.F1) taking hops: 1
              7/18/2015 1:31:35 PM Insteon Received STX 0x50 (Raw Insteon Rec):36 FE F1 11 00 04 CB 06 00 Debouncing repeat.
              7/18/2015 1:31:48 PM Insteon Starting Scheduled Polling...
              7/18/2015 1:31:48 PM Insteon ..Finished Scheduled Polling for 0 devices.
              7/18/2015 1:32:35 PM Insteon Edit Insteon Device #17 Addr: 0E.1F.DE, Name:Keypad, Location:Master Bedroom
              I can hear the new keypad beep when this process is attempted. I can see stuff in the log when I press a button on it, so it seems like comms are working. (Example below)
              7/18/2015 1:28:15 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 00 00 02 CB 11 00
              7/18/2015 1:28:15 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 11 00 02 CB 06 00
              7/18/2015 1:28:17 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 00 00 02 CB 13 00
              7/18/2015 1:28:17 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 13 00 02 C7 06 00
              7/18/2015 1:28:18 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 00 00 01 CB 13 00
              7/18/2015 1:28:18 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 13 00 01 CB 06 00
              Is there any hope for this?
                try manual linking the kpl to the plm first and they the swap. start with the plm in linking mode then start the kpl linking mode
                Mark
                HS3 Pro 3.0.0.534
                  Well darn, still no joy...
                  AFAIK, they did link.
                  7/18/2015 3:29:39 PM Insteon Pass 1, updating devices that appear to have stale link tables...RF devices are ignored...
                  7/18/2015 3:29:39 PM Insteon Pass 2, Now attempting to reprogram your system for the replacement device...
                  7/18/2015 3:29:40 PM Insteon Program And Replace Device - Process starting... (0E.1F.DE-34.DD.44)...
                  7/18/2015 3:29:40 PM Insteon Step 1 of 5: Programming new device with links...
                  7/18/2015 3:30:07 PM Insteon Did not receive a response from (34.DD.44). Try #5 failed.
                  7/18/2015 3:30:07 PM Insteon Your system could not be reprogrammed.Program And Replace Device - The destination device could not be programmed, function aborted before system/device changes were made.
                  7/18/2015 3:30:07 PM Insteon Replace device routine complete.
                  7/18/2015 3:30:43 PM Motion Big Room No Motion
                  7/18/2015 3:31:09 PM Insteon Scheduled polling enabled.
                  7/18/2015 3:31:17 PM Insteon Edit Insteon Device #17 Addr: 0E.1F.DE, Name:Keypad, Location:Master Bedroom
                  7/18/2015 3:31:18 PM Insteon Starting Scheduled Polling...
                  7/18/2015 3:31:18 PM Insteon ..Finished Scheduled Polling for 0 devices.
                  7/18/2015 3:31:22 PM Insteon Replace Device Selected
                  7/18/2015 3:31:22 PM Insteon In Replace - Device #17 Addr: 0E.1F.DE, Name:Keypad, Location:Master Bedroom
                  7/18/2015 3:31:33 PM Insteon Starting Scheduled Polling...
                  7/18/2015 3:31:33 PM Insteon ..Finished Scheduled Polling for 0 devices.
                  7/18/2015 3:31:37 PM Insteon Replace Device Confirmation Selected
                  7/18/2015 3:31:37 PM Insteon Launching new BackgroundUpdate Thread with job type 10...
                  7/18/2015 3:31:37 PM Insteon In BackgroundUpdate Thread...
                  7/18/2015 3:31:37 PM Insteon Calling AddRecord for 34.DD.44 1 True
                  7/18/2015 3:31:37 PM Insteon Sending command 02 6F 41 A2 01 34 DD 44 00 00 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True
                  7/18/2015 3:31:37 PM Insteon ..Got RF PLM Response 02 6F 41 A2 01 34 DD 44 00 00 00 15
                  7/18/2015 3:31:37 PM Insteon Sending Insteon ID Broadcast for '34.DD.44'
                  7/18/2015 3:31:37 PM Insteon Sending command 02 62 34 DD 44 0F 10 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:37 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 10 00 06
                  7/18/2015 3:31:38 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 A7 10 FF
                  7/18/2015 3:31:38 PM Insteon Got i2cs type broadcast for Insteon ID 34.DD.44 Need to link device to RF PLM now...
                  7/18/2015 3:31:38 PM Insteon Attempting to link the i2cs device 34.DD.44 to the RF PLM
                  7/18/2015 3:31:38 PM Insteon Sending command 02 64 01 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:38 PM Insteon ..Got RF PLM Response 02 64 01 00 06
                  7/18/2015 3:31:38 PM Insteon Sending command 02 62 34 DD 44 1F 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:38 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 06
                  7/18/2015 3:31:39 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 09 00
                  7/18/2015 3:31:39 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:39 PM Insteon PLM_ProcessInBuffer received STX 0x53 (Link Completed):01 00 34 DD 44 01 41 44
                  7/18/2015 3:31:41 PM Insteon Sending command 02 62 34 DD 44 1F 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:41 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 06
                  7/18/2015 3:31:41 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 09 00
                  7/18/2015 3:31:41 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:41 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 01 41 44 87 01 76
                  7/18/2015 3:31:41 PM Insteon Got i2cs type broadcast for Insteon ID 34.DD.44 of type , Firmware version
                  7/18/2015 3:31:41 PM Insteon Sending command 02 62 34 DD 44 0F 08 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:42 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 08 00 06
                  7/18/2015 3:31:42 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 08 00
                  7/18/2015 3:31:42 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:42 PM Insteon Pass 1, updating devices that appear to have stale link tables...RF devices are ignored...
                  7/18/2015 3:31:42 PM Insteon Pass 2, Now attempting to reprogram your system for the replacement device...
                  7/18/2015 3:31:42 PM Insteon Calling AddRecord for 34.DD.44 1 True
                  7/18/2015 3:31:42 PM Insteon Sending command 02 6F 41 A2 01 34 DD 44 00 00 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True
                  7/18/2015 3:31:42 PM Insteon ..Got RF PLM Response 02 6F 41 A2 01 34 DD 44 00 00 00 15
                  7/18/2015 3:31:42 PM Insteon Sending Insteon ID Broadcast for '34.DD.44'
                  7/18/2015 3:31:42 PM Insteon Sending command 02 62 34 DD 44 0F 10 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:43 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 10 00 06
                  7/18/2015 3:31:43 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 10 00
                  7/18/2015 3:31:43 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:43 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 01 41 44 87 01 76
                  7/18/2015 3:31:43 PM Insteon Got controller/responder type broadcast for Insteon ID 34.DD.44 of type 0141, Firmware version 44
                  7/18/2015 3:31:43 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 01 41 44 87 01 76 Debouncing repeat.
                  7/18/2015 3:31:43 PM Insteon Program And Replace Device - Process starting... (0E.1F.DE-34.DD.44)...
                  7/18/2015 3:31:43 PM Insteon Step 1 of 5: Programming new device with links...
                  7/18/2015 3:31:43 PM Insteon GetInsteonProtocol for '34.DD.44'
                  7/18/2015 3:31:43 PM Insteon Sending command 02 62 34 DD 44 0F 0D 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:43 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 0D 00 06
                  7/18/2015 3:31:44 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 0D 02
                  7/18/2015 3:31:44 PM Insteon Got Insteon Protocol Engine response from Insteon ID 34.DD.44, Protocol i2CS
                  7/18/2015 3:31:44 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:44 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F FF 08 E2 01 1C F5 09 FF 1F 01 9D to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:44 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F FF 08 E2 01 1C F5 09 FF 1F 01 9D 06
                  7/18/2015 3:31:45 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00
                  7/18/2015 3:31:45 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F F7 08 E2 02 1C F5 09 FF 1F 02 A3 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:45 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:45 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F F7 08 E2 02 1C F5 09 FF 1F 02 A3 06
                  7/18/2015 3:31:45 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00 Debouncing repeat.
                  7/18/2015 3:31:48 PM Insteon Did not receive a response from (34.DD.44). Try #1 failed.
                  7/18/2015 3:31:48 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F F7 08 E2 02 1C F5 09 FF 1F 02 A3 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:48 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F F7 08 E2 02 1C F5 09 FF 1F 02 A3 06
                  7/18/2015 3:31:48 PM Insteon Starting Scheduled Polling...
                  7/18/2015 3:31:48 PM Insteon ..Finished Scheduled Polling for 0 devices.
                  7/18/2015 3:31:48 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00
                  7/18/2015 3:31:48 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:48 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:49 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 06
                  7/18/2015 3:31:49 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00 Debouncing repeat.
                  7/18/2015 3:31:52 PM Insteon Did not receive a response from (34.DD.44). Try #1 failed.
                  7/18/2015 3:31:52 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:52 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F EF 08 E2 03 1C F5 09 FF 1F 03 A9 06
                  7/18/2015 3:31:52 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00
                  7/18/2015 3:31:52 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F E7 08 E2 04 1C F5 09 FF 1F 04 AF to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:52 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:52 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F E7 08 E2 04 1C F5 09 FF 1F 04 AF 06
                  7/18/2015 3:31:53 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00 Debouncing repeat.
                  7/18/2015 3:31:55 PM Insteon Did not receive a response from (34.DD.44). Try #1 failed.
                  7/18/2015 3:31:55 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F E7 08 E2 04 1C F5 09 FF 1F 04 AF to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:55 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F E7 08 E2 04 1C F5 09 FF 1F 04 AF 06
                  7/18/2015 3:31:56 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00
                  7/18/2015 3:31:56 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F DF 08 E2 05 1C F5 09 FF 1F 05 B5 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:56 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:31:56 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F DF 08 E2 05 1C F5 09 FF 1F 05 B5 06
                  7/18/2015 3:31:57 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00 Debouncing repeat.
                  7/18/2015 3:31:59 PM Insteon Did not receive a response from (34.DD.44). Try #1 failed.
                  7/18/2015 3:31:59 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F DF 08 E2 05 1C F5 09 FF 1F 05 B5 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:31:59 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F DF 08 E2 05 1C F5 09 FF 1F 05 B5 06
                  7/18/2015 3:32:00 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00
                  7/18/2015 3:32:00 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:32:00 PM Insteon Received a Direct ACK from 34.DD.44
                  7/18/2015 3:32:00 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB 06
                  7/18/2015 3:32:01 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 27 2F 00 Debouncing repeat.
                  7/18/2015 3:32:03 PM Insteon Did not receive a response from (34.DD.44). Try #1 failed.
                  7/18/2015 3:32:03 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:32:03 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB 06
                  7/18/2015 3:32:03 PM Insteon Starting Scheduled Polling...
                  7/18/2015 3:32:03 PM Insteon ..Finished Scheduled Polling for 0 devices.
                  7/18/2015 3:32:03 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 A7 2F FF
                  7/18/2015 3:32:05 PM Insteon Did not receive a response from (34.DD.44). Try #2 failed.
                  7/18/2015 3:32:05 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:32:05 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB 06
                  7/18/2015 3:32:06 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 A7 2F FF
                  7/18/2015 3:32:08 PM Insteon Did not receive a response from (34.DD.44). Try #3 failed.
                  7/18/2015 3:32:08 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:32:08 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB 06
                  7/18/2015 3:32:08 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 A7 2F FF
                  7/18/2015 3:32:10 PM Insteon Did not receive a response from (34.DD.44). Try #4 failed.
                  7/18/2015 3:32:10 PM Insteon Sending command 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                  7/18/2015 3:32:10 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 1F 2F 00 00 02 0F D7 08 E2 06 1C F5 09 FF 1F 06 BB 06
                  7/18/2015 3:32:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 A7 2F FF
                  7/18/2015 3:32:13 PM Insteon Did not receive a response from (34.DD.44). Try #5 failed.
                  7/18/2015 3:32:13 PM Insteon Program And Replace Device - The destination device could not be programmed, function aborted before system/device changes were made.
                  7/18/2015 3:32:13 PM Insteon Your system could not be reprogrammed.Program And Replace Device - The destination device could not be programmed, function aborted before system/device changes were made.
                  7/18/2015 3:32:13 PM Insteon Replace device routine complete.
                  7/18/2015 3:32:13 PM Insteon BackgroundUpdate Thread Complete...
                  7/18/2015 3:32:18 PM Insteon Starting Scheduled Polling...
                  7/18/2015 3:32:18 PM Insteon ..Finished Scheduled Polling for 0 devices.
                  7/18/2015 3:32:20 PM Insteon Edit Insteon Device #17 Addr: 0E.1F.DE, Name:Keypad, Location:Master Bedroom
                  7/18/2015 3:32:30 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 00 00 01 CB 11 00
                  7/18/2015 3:32:30 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 11 00 01 CB 06 00
                  7/18/2015 3:32:32 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 00 00 01 CB 13 00
                  7/18/2015 3:32:32 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 13 00 01 C7 06 00
                  The last of that was me turning the load on and off locally.
                    the kpl is responding as if it doesn't recognize the plm as a valid controller
                    how about as a test, see if you can register the new kpl as a new device. if this works, delete the device from the registration, and then try the replace routine
                    if this doesn't work, then I'm out of ideas
                    Mark
                    HS3 Pro 3.0.0.534
                      That did it.
                      Now we have joy.
                      Adding it as a new device, deleting it, then running replace worked. I haven't fully verified that all links and groups are there, but so far everything I've tried has worked.
                      Thanks much, especially on a Saturday. I do appreciate it.
                        Glad you got it working. I'll have to check the replace routine code.
                        Mark
                        HS3 Pro 3.0.0.534
                          While you're looking, I have this new odd one in the log...
                          Unknown command sent to KPL buttons...exiting
                          I think it's related to my attempt to combine the top two buttons (making a 7 button keypadlinc). It worked for the older keypadlinc, but not as much for the new one. It's not a big deal, and I'm sure I can get around it one way or another...
                          7/18/2015 5:56:46 PM Insteon Received message from 2nd Master Bedroom Keypad (34.DD.44) taking hops: 1
                          7/18/2015 5:56:46 PM Insteon Received [7 (Master Bedroom Keypad - Light) Go OFF
                          7/18/2015 5:56:46 PM Insteon ProcessGroupBroadcast: Device 2nd Master Bedroom Keypad Button B: Keypad - Light (34.DD.44) is group broadcast source (tgt group/button:2) sending cmd 13
                          7/18/2015 5:56:46 PM Insteon Setting status and value for device [7. Old status:2 Old Value:100, New Status:3 New Value:0
                          7/18/2015 5:56:46 PM Insteon Setting status and value for device [6. Old status:2 Old Value:100, New Status:3 New Value:0
                          7/18/2015 5:56:46 PM Insteon Checking for keypadlinc button sync on device 34.DD.44 src index 1, SrcIsSyncTarget=True...
                          7/18/2015 5:56:46 PM Insteon Checking for keypadlinc button sync on device 34.DD.44 src index 2, SrcIsSyncTarget=True...
                          7/18/2015 5:56:46 PM Insteon --KPL button Sync, Need to turn button 1 OFF because button 2 went OFF
                          7/18/2015 5:56:46 PM Insteon Setting status and value for device [6. Old status:3 Old Value:0, New Status:3 New Value:0
                          7/18/2015 5:56:46 PM Insteon --KPL button Sync, Need to turn button 2 OFF because button 1 went OFF
                          7/18/2015 5:56:46 PM Insteon Setting status and value for device [7. Old status:3 Old Value:0, New Status:3 New Value:0
                          7/18/2015 5:56:46 PM Insteon ProcessGroupBroadcast: Updating Group #20 status
                          7/18/2015 5:56:46 PM Insteon Setting value for \7
                          7/18/2015 5:56:46 PM Insteon ProcessGroupBroadcastUpdateResponders: Located remote link record match for group broadcast - Device:34.DD.44 link record #63 target channel 1
                          7/18/2015 5:56:46 PM Insteon Sending command 02 62 34 DD 44 0F 2F 0B to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                          7/18/2015 5:56:46 PM Insteon Checking for keypadlinc button sync on device 34.DD.44 src index 1, SrcIsSyncTarget=False...
                          7/18/2015 5:56:46 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 00 01 02 CB 13 02
                          7/18/2015 5:56:46 PM Insteon ..Got NAK from the RF PLM for command
                          7/18/2015 5:56:46 PM Insteon ..Retry #1 required. Pausing 250ms for RF PLM to clear...
                          7/18/2015 5:56:46 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 13 00 02 CB 06 00
                          7/18/2015 5:56:46 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 2F 0B 06
                          7/18/2015 5:56:47 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 2F 0B
                          7/18/2015 5:56:47 PM Insteon SyncResponderDevices called for device code: [6
                          7/18/2015 5:56:47 PM Insteon Received message from 2nd Master Bedroom Keypad (34.DD.44) taking hops: 1
                          7/18/2015 5:56:47 PM Insteon Received a Direct ACK from 2nd Master Bedroom Keypad (34.DD.44)
                          7/18/2015 5:56:47 PM Insteon Sending sync command to linked responder device: 2nd Master Bedroom Keypad Button B: Keypad - Light (34.DD.44)
                          7/18/2015 5:56:47 PM Insteon Attempting to get a KPL LED status response from Insteon device 34.DD.44
                          7/18/2015 5:56:47 PM Insteon Sending command 02 62 34 DD 44 0F 19 01 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                          7/18/2015 5:56:47 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 19 01 06
                          7/18/2015 5:56:47 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 00 04
                          7/18/2015 5:56:47 PM Insteon Unknown command sent to KPL buttons...exiting
                          7/18/2015 5:56:47 PM Insteon SyncResponderDevices called for device code: [7
                          7/18/2015 5:56:47 PM Insteon Sending sync command to linked responder device: 2nd Master Bedroom Keypad Button A/Load: Light (34.DD.44)
                          7/18/2015 5:56:47 PM Insteon Setting status and value for device [6. Old status:3 Old Value:0, New Status:3 New Value:0
                          7/18/2015 5:56:47 PM Insteon Checking for keypadlinc button sync on device 34.DD.44 src index 1, SrcIsSyncTarget=True...
                          7/18/2015 5:56:47 PM Insteon --KPL button Sync, Need to turn button 2 OFF because button 1 went OFF
                          7/18/2015 5:56:47 PM Insteon Setting status and value for device [7. Old status:3 Old Value:0, New Status:3 New Value:0
                          7/18/2015 5:56:48 PM Insteon ..Got RF PLM Response 02 62 34 DD 44 0F 19 01 06
                          7/18/2015 5:56:48 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 DD 44 1C F5 09 2B 00 04 Debouncing repeat.
                            I'm also getting this:
                            7/18/2015 6:12:38 PM Error Exception creating device enumerator at 0: Object reference not set to an instance of an object
                            When trying to:
                            Insteon: Light 2nd Master Bedroom Keypad Button A/Load: Light On Level:100, Ramp Rate:2 Sec.
                            (The light does not turn on.)
                              not sure what's going on. does the kpl work correctly when controlled locally
                              Mark
                              HS3 Pro 3.0.0.534
