How Do I Trigger Manual Polling of Devices?
    Mark, I want to be able to poll Insteon devices for status through either a script or an event on demand the same way you can select "Poll Devices For Status" icon in the GUI. Will this poll which KPL Buttons (not load) are ON as well?
    How can this be done?
    Jean-Marie G. Vaneskahian
    jean@vaneskahian.com
    Your best bet is the standard hs polldevice method.
    here is the hs3 protocol for a vb.net script
    Public Function PollDevice(ByVal dvref As Integer) As IPlugInAPI.PollResultInfo Implements HomeSeerAPI.IPlugInAPI.PollDevice
    it's a little different for hs2
    Public Function PollDevice(ByVal ref As Integer, ByVal housecode As String, ByVal devicecode As String) As String
    Mark
    HS3 Pro 3.0.0.534
      Mark,
      I am running HS3, would you do me the small favor of showing me the PollDevice method in use in an example script in vb.net (I assume 1 or 2 lines of code once you have the device reference)?
      I do not understand the class IPlugInAPI.PollResultInfo Implements HomeSeerAPI.IPlugInAPI.PollDevice
      Say an Insteon 8 button KPL had a device reference of 230, would a call to the PollDevice method on device ref 230 return anything or just simply populate the current and proper value and status of the 8 buttons on the KPL device in HomeSeer?
        check out this thread. is discusses polling, specifically post #4
        don't worry about the "Implements HomeSeerAPI.IPlugInAPI.PollDevice"
        your return class is IPlugInAPI.PollResultInfo
        Mark
        HS3 Pro 3.0.0.534
          There was no link I saw, what thread?
            http://board.homeseer.com/showthread.php?t=172150
            Mark
            HS3 Pro 3.0.0.534
