How can I set up an event with conditions "device on or off" but I need it to wait 30 seconds before checking the condition? The event is triggered from Insteon Door Sensor
30 Second Delay
you probably need two events. one to start an event with a 30sec delay after the On or Off, then a second action to call the second event with the condition you want to check.
you might get other suggestions in the hs general forum.Mark
HS3 Pro 3.0.0.534
Originally posted by mnsandler View Postyou probably need two events. one to start an event with a 30sec delay after the On or Off, then a second action to call the second event with the condition you want to check.
you might get other suggestions in the hs general forum.Mike
In HS3 there is an advanced option (click airplane) to display the option which requires the conditions to be tested before the second event runs. check the box!Last edited by mnsandler; August 9, 2015, 08:19 AM.Mark
HS3 Pro 3.0.0.534
if this doesn't do it, please explain what you are trying to do; there is probably another wayMark
HS3 Pro 3.0.0.534
Originally posted by mnsandler View PostIn HS3 there is an advanced option (click airplane) to display the option which requires the conditions to be try before the second event runs. check the box!, very useful!)
Mike
Originally posted by rmuziani View PostThat might work, but I am still on 2.0Mark
HS3 Pro 3.0.0.534
