I finally got time to move everything over to the new Hometroller and HS3. A while back my old Hometroller died and I was just running the system using the links in the devices - no central control at all. Everything ran fine. Since I've started using the new Hometroller with HS3, I've been having quite a few problems.
I've attached the Insteon error log as a zip file.
System:
Hometroller Pro 6
HS3 Pro Edition 3.0.0.194 (Windows)
Insteon plugin 3.0.5.20
Only non default setting: KPLGroupLinks=False
HSTouch Server 3.0.0.69
Symptoms:
After pressing a button on a KPL the backlight starts to flicker. Briefly pulling out the tab stops this. It's inconsistent whether the button action occurs or not.
Linked buttons not performing their action. For example, I have 1 SwitchLinc and 1 button on 2 KPLs cross linked (Sharon's Office Light, KPL by Hall Button C, KPL by MBR Button C). The SwitchLinc controls the load. If I press the button on one KPL it works as expected. If I press it on the other KPL it does not (SwitchLinc isn't turned on/off and button backlight doesn't change state). Usually the backlight on the KPL starts flickering as above.
HSTouch for Android - It populates with the devices but doesn't turn devices on/off when pressing button in HSTouch.
When I VPNed to the HomeTroller, there was a Chrome window open with an error message from the Insteon plugin. I think the error at the top of the log is what it was displaying.
I don't know if this is enough information. Let me know if there's something more I can give you.
Panagiotis
System:
Hometroller Pro 6
Symptoms:
Panagiotis
