Just upgraded my Hometroller Zee to HS3 ZEE S2 Edition 3.0.0.205 and noticed on reboot that Insteon plugin did not connect back up. I realized that I was out of date on the most recent version of the plugin so I updated that as well. It still won't connect. I've included a list of my USB devices as well as a detailed Log from the Insteon plugin.
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 005: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Insteon Plug-in Error Log Generated 9/21/2015 6:12:20 PM
-----------*Error Message*----------------
Error: Forced error / log generation -- 9/21/2015 6:12:20 PM
--------*Initialization Log*--------------
9/21/2015 6:11:32 PM - Host System: () 3.0.0.205
9/21/2015 6:11:32 PM - Plugin: HSPI_Insteon.DLL - v3.0.5.35
9/21/2015 6:11:32 PM - Insteon Support library (Insteon.dll) version: 1.0.5.35
9/21/2015 6:11:32 PM - RegisterCallback Completed
9/21/2015 6:11:32 PM - Enter InitIO
9/21/2015 6:11:32 PM - Enter InitPlugin
9/21/2015 6:11:32 PM - Global initialization of plug-in required, starting up.
9/21/2015 6:11:32 PM - Initializing Insteon hardware interface...
9/21/2015 6:11:32 PM - In ProcessRawReceiveThread
9/21/2015 6:11:32 PM - Initializing Interface...
9/21/2015 6:11:32 PM - In PLMBuffer_ProcessBufferThread
9/21/2015 6:11:32 PM - Sending command 02 60 to Interface, (Expecting 6 bytes e$
9/21/2015 6:11:32 PM - ..Got NAK from the Interface for command
9/21/2015 6:11:32 PM - ..Retry #1 required. Pausing 250ms for Interface to cle$
9/21/2015 6:11:34 PM - ..did not receive a response from the Interface
9/21/2015 6:11:35 PM - ..did not receive a response from the Interface
9/21/2015 6:11:35 PM - Insteon hardware interface initialization failed.
9/21/2015 6:11:35 PM - Exit InitIO
-----------*Pre-Error Log*----------------
9/21/2015 6:11:35 PM - Could not contact Interface on /dev/ttyUSB1
9/21/2015 6:11:35 PM - Port_DataReceived Error: Specified port is not open.
This continues to repeat forever.
