So, about an hour ago I got a notification that the plugin could not connect to my 2413U.
I've tried: restarting the plugin, restarting homeseer, switching USB cables, unplugging the PLM, leaving the PLM and the HomeSeer server off for about 10 minutes, and checking windows device manager, but nothing seems to have worked.
Here is the initial log of when it first happened (in order from newest to oldest)
and here's the log from the most recent restart:
in device manager this is what I see:
unfortunately, the light on the PLM is not lit, but it hasn't been lit since I purchased the PLM directly from SmartHome back in (I think) 2013 and it has always been on COM5 since I upgraded to HS3 on a new server.
EDIT: I can't get the SimpleHomeNet Utility to connect to the PLM either, so I would say that it's safe to say it isn't an issue with the plugin or with HomeSeer, but with either the PLM or the USB port on the server. Tomorrow I will try a different USB port and see if that works. If not, do you recommend I try resetting the PLM?
Oct-30 1:30:29 AM Insteon The serial port driver does not support the recovery process.
Oct-30 1:30:29 AM Insteon Attempting to restart the port and Interface...
Oct-30 1:30:28 AM Pushover 3P Pushover Notification Sent
Oct-30 1:30:28 AM Event Event Trigger "Auto Insteon Failure"
Oct-30 1:30:28 AM Insteon Scheduled polling temporarily stopped.
Oct-30 1:30:28 AM Insteon Warning! Communications lost. Attempting to restart the port...
Oct-30 1:30:28 AM Insteon Interface_TrapError called from SendHex
Oct-30 1:30:28 AM Insteon The RF PLM has failed to transmit the last 10 commands.
Oct-30 1:30:17 AM Insteon TransmitGroupMsg called for device code: Group:19, RF PLM Group 19
Oct-30 1:30:17 AM Insteon Transmit failed to device Foyer Lights (1A.26.02) for cmd 00 00 00 1A 26 02 0F 13 00 after 5 tries.
Oct-30 2:08:53 AM Insteon Error: An attempt was made to initialize an external Insteon device support but the plug-in has not completed initializing. The request was denied.
Oct-30 2:08:51 AM Insteon Error: An attempt was made to initialize an external Insteon device support but the plug-in has not completed initializing. The request was denied.
Oct-30 2:08:38 AM Insteon Could not contact Interface on COM5
Oct-30 2:08:33 AM Insteon RegisterCallback Completed
Oct-30 2:08:33 AM Insteon Insteon Support library (Insteon.dll) version: 1.0.5.20
Oct-30 2:08:33 AM Insteon Host System: () 3.0.0.208
Oct-30 2:08:33 AM Insteon Plugin: HSPI_Insteon.DLL - v3.0.5.20
