Okay this one is strange, and I cannot seem to find a cause. Seems like once a day, I am finding the following line in the HS2 HomeSeer.LOG.
11/3/2015 8:33:40 AM ~!~Insteon~!~Received #10 (Garage Motion Sensor - Battery Level) Go OFF Fast
Most days this seems to occur around 8:30AM. However, I have also found it a few other times on other days.
This is the ONLY entry at all associated with device #10 which is the battery level of one of my Insteon Motion Sensors. I have 6 of the sensors in total, and none of the other 5 seem to have this issue.
The problem is that after this is received, the HomeSeer device loses its value, (it goes to 0) which has let to false low battery reports - until the value is refreshed.
I currently have the poll settings value for all motions sensors set to 10, so it will refresh the battery level value after the 10th occupancy trigger.
I have looked at all links and cannot find any indication that a link is improperly assigned to any other Insteon device. I have also completely deleted the Motion Sensor, and re-added it after performing a factory reset on the sensor device. The behavior promptly came back the next day.
I've turned on Insteon Plugin debug logging so I may have more in a day or so when this happens again.
I started wondering if maybe this was a Dusk/Dawn device that had somehow gotten "cross-wired" with the battery level. But the Dusk/Dawn device for this motion sensor actually continues to work properly - it goes on at dark and off at dawn.
Lastly, I have scoured my scripts and events to see if I could find any reference to this device or to the Insteon values, and I cannot find any reference.
Anyone seen this odd behavior before? Or anything else I should look for?
