Originally posted by joegr
View Post
I was reluctant to do the big job of migrating from HS2 to HS3, but it really isn't so bad. In fact it gave me a chance to clean up a lot of stuff that had "evolved" poorly. Now that I'm done, I can say that it is really worthwhile. Once over the small learning curve, HS3 is much nicer to use than HS2, and considerably more powerful.
You can also make good use of Jon00's "HS2 to HS3 Connector" software (free with donation). You can have both HS3 and HS2 running simultaneously and keep devices synchronized in both. It works really well and provides a simple migration path so you can move events bit by bit as time allows and ultimately shut down HS2. Or keep HS2 running with the plug-ins that are not supported on HS3.
