It is a bit late and I may be missing something easy. When I turn a device on/off from HS, this is all I get in the detailed logs...
I don't see any insteon commands being sent. I do see commands going back and forth for the thermostat (external devcie). The device status will change on the HS web page. However, it doesn't update on HSTouch. I don't know if that is related.
It was working fine this morning. However, I am in the process of getting some hard-wired sensors going and wanted to get my Homevision working. So, I did disable/re-enable it because I wasn't able to get to the page where I set the com port for that. BTW, I also change the com port for the PLM too, but it is working. I even did a reset/reprogram on it. I can test communication and all is good. I have to say that maybe this is some weird HS issue and not a insteon plugin problem at all, but I am perplexed.
11/27/2015 11:42:54 PM - Device Control - Device: Basement Sconce Light (\1) ON 11/27/2015 11:42:54 PM - Insteon - Processing SetIOEx for device - \1 Cmd: 2 Bright: 0 Data1: 0 Data2: 0
