I'm new so I don't know if my terminology is correct. All my devices are found and functional in homeseer. In my master bedroom I have a switch that actually controls the light load. I created a virtual 3-way switch on the other side of the room with another dimmer. I then created a scene such that when either switch is dimmed, the other paddle knows/displays the current lighting level on the dimmer.
Using HsTouch, I wanted to clean up/hide duplicate entries that control the lighting(the actual load bearing dimmer, the connected 3-way, and the scene for them).
Here's my issue...I have to remove the two individual dimmer entries since using either one on HsTouch doesn't change the state of the other dimmer since it doesn't use the connecting scene. Well, using the scene, I can't seem to dim the lights. Only on or off. I tried to enter a range/slider on the scene entry in homeseer, but I couldn't get it to work. What else can I try to use a scene that correctly disperses light status to all connected dimmers and still be able to dim? Thanks.
