I have an Amazon Echo linked to a Hub for voice-controlling some devices. But the Hub is limited because Echo can't activate scenes, nor does it have the nifty feature of "Sync linked responders" like the plug-in does. (I know Echo has a HomeSeer skill, which I do have enabled, but it is not nearly as reliable as Hub integration.)
My kitchen lights have are controller by a three-way switch, plus there is another "bar" light that really should have been part of the same circuit, so I linked it to the kitchen switches. When either kitchen switch is locally controlled, it controls the other kitchen switch and the bar light. If I use the Echo to control the lights, however, it only will control the master switch, leaving the slave as is, and not even controlling the bar light.
What I want to do is have HomeSeer react to the Hub controlling the kitchen lights switch (so I can have it make up for where the Hub lacks controlling multiple devices with one command and have "Alexa, turn off the kitchen lights" result in control of all three switches). The log shows that the plug-in doesn't see the switch being controlled by the Hub. I thought the switch would report to HS, but I see the link is actually labeled "local control reports to HS," and local control isn't what is happening.
Do you have any ideas how I can have the plug-in know when the kitchen switch has been controlled by another PLM? Can the Hub be configured to have a link to report all controls to the HS PLM?
Scott
(Saying, "Alex, tell HomeSeer to turn off the kitchen lights" is not reliable, for whatever reason. It may fail the first time, then be successful the second time, perhaps indicating a connection to MyHS timed out the first time. But if it doesn't work 100% of the time, I don't want to use it. It defeats the purpose of automation if I have to ask Echo to do it two, three times and your wife is giving you this look like, "Why did you spend all this money when I could have turned it off and on like 10 times by now." I wish Echo could be configured to connect directly to my HS installation instead of proxied through MyHS.)
Scott
