I'm sure this is covered somewhere, but I don't see it. Anyway, I would like the lights on my KeyPadLinc to reflect reality. In other words, if Button A controls my floor lamps, but I turn them on from a different remote, can I get button A to light up? And of course, vice-versa. Is this only doable from an event?
Updating Lights On KeyPadLinc
This topic is closed.
you should be to create insteon links from other devices (if the device is an insteon remote or other insteon switch) to control the A btn. this is the best solution. doesn't require hs intervention.
otherwise the 'control a device' event action can be use to turn kp btns on and off based on any trigger you wantMark
HS3 Pro 4.2.19.5
