I am starting my migration finally to HS3.
Got Insteon Hub working on HS3 with Mark's plugin beta v3.0.5.84
I still have my HS2 running using a serial PLM and Mark's plugin v2.0.0.3
I tested a adding single device to HS3 but find that the devices will register weird links between systems and I am not sure of the proper migration process and which ones to delete/maintain.
For instance:
Before I start - HS2 has device registered in HomeSeer (5 links/ 3 HS, 2 2nd device)
Link #4 Outlet controls Dining Room DR/LR Keypad Button A (23.CE.C2)
Link #5 Outlet has local control reporting to HomeSeer
Link #3 Outlet is controlled by Dining Room DR/LR Keypad Button A (23.CE.C2) - On Level 100%, Ramp Rate 2 Sec.
Link #1 Outlet is controlled by HomeSeer using RF PLM Group #0 (i2CS Registration Link) - On Level 100%, Ramp Rate .5 Sec.
Link #2 Outlet is controlled by HomeSeer using RF PLM Group #254 (HomeSeer All Devices Group) - On Level 100%, Ramp Rate .1 Sec.
Add the same device to HS3 - Cannot manual Add have to TAP-ADD (8 links/ I think 6-8 are HS3 new, 1-3 are HS2 old, and 4-5 are my 2nd link)
Link #2 Outlet controls Unregistered Device (39.01.AA)
Link #5 Outlet controls Unregistered Device Link 3 (23.CE.C2)
Link #6 Outlet has local control reporting to HomeSeer
Link #7 Outlet is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level: 100%, Ramp Rate: .5 Sec.
Link #8 Outlet is controlled by HomeSeer using Hub Group #254 (HomeSeer All Devices Group) - On Level: 100%, Ramp Rate: .1 Sec.
Link #1 Outlet is controlled by Unregistered Device Group 0 (39.01.AA) - On Level: 100%, Ramp Rate: .5 Sec.
Link #3 Outlet is controlled by Unregistered Device Group 254 (39.01.AA) - On Level: 100%, Ramp Rate: .1 Sec.
Link #4 Outlet is controlled by Unregistered Device Group 3 (23.CE.C2) - On Level: 100%, Ramp Rate: 2 Sec.
Then original HS2 has unread links and if I re-read I get: (same 8 links, I think 1-3 HS2, 4-5 2nd link, 6-8 HS3)
Link #5 Outlet controls Dining Room DR/LR Keypad Button A (23.CE.C2)
Link #6 Outlet controls Unregistered Device (3C.16.17)
Link #2 Outlet has local control reporting to HomeSeer
Link #4 Outlet is controlled by Dining Room DR/LR Keypad Button A (23.CE.C2) - On Level 100%, Ramp Rate 2 Sec.
Link #3 Outlet is controlled by HomeSeer using RF PLM Group #254 (HomeSeer All Devices Group) - On Level 100%, Ramp Rate .1 Sec.
Link #7 Outlet is controlled by Unregistered Device Group 0 (3C.16.17) - On Level 100%, Ramp Rate .5 Sec.
Link #8 Outlet is controlled by Unregistered Device Group 254 (3C.16.17) - On Level 100%, Ramp Rate .1 Sec.
So my question is: While I have 2 systems running, should I perform this process...
1. HS3 add
2. HS2 re-read (that way both HS will be in sync as long as I poll periodically)
3. when complete HS3 migration complete - remove HS2 links from HS3 devices
Thanks in advance.
Chuck
For instance:
1. HS3 add
Thanks in advance.
Chuck
