what plugin version are you running? have you tried the latest beta? i think i fixed this issue you mentioned awhile ago
Hidden door sensor low batt warning changes status to Open
This topic is closed.
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postwhat plugin version are you running? have you tried the latest beta? i think i fixed this issue you mentioned awhile ago
I stay relatively current. But I can try a latest Beta if you think it is a more recent fix.
nothing more current. if its not too much trouble, can you delete the device from the plugin, and register it againMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postnothing more current. if its not too much trouble, can you delete the device from the plugin, and register it again
I'll try and find an older battery (or maybe drain one) to install again and see if I can get the same low battery condition to fire again.
Originally posted by LeeIII View Post
I have deleted the device from the plugin page, and have re-added it as a new device, For this one I only had 6-7 events so it wasn't too much trouble to click through and re-add it back as the Event triggers.
Below is a snippet of a log for a heartbeat that my hidden door sensor sends. It seems to always activate the sensor device to ON (OPEN), when the device gets into the low battery situation. Below is a heartbeat that was sent this morning that triggered the device door open status. Maybe I have a bum sensor?
Dec-22 7:57:44 AM Insteon Received a Direct ACK from Sensors Door Basement Door (45.CF.3E): 45 CF 3E 33 E1 0D 2B 19 3F
Dec-22 7:57:44 AM Insteon Setting status and value for device 45.CF.3E:3. Old status:100 Old Value:100, New Status:2 New Value:100
Dec-22 7:57:44 AM Event Event Trigger "SECURITY SECURITY - Basement Door OPEN"
Dec-22 7:57:44 AM Insteon Setting status and value for device 45.CF.3E:1. Old status:0 Old Value:0, New Status:2 New Value:100
Dec-22 7:57:44 AM Insteon Setting value for device 45.CF.3E:5. Old Value:1.234, New Value: 1.2339
Dec-22 7:57:44 AM Insteon Hidden Door Sensor Sensors Door Basement Door Door Sensor: (45.CF.3E) battery level read successfully.
Dec-22 7:57:44 AM Insteon Received STX 0x50 (Raw Insteon Rec):45 CF 3E 33 E1 0D 2B 19 3F
Dec-22 7:57:43 AM Insteon Received STX 0x50 (Raw Insteon Rec):45 CF 3E 00 00 03 CB 11 03
Dec-22 7:57:43 AM Insteon Received STX 0x50 (Raw Insteon Rec):45 CF 3E 13 00 04 CB 06 00 Debouncing repeat.
Dec-22 7:57:42 AM Insteon ..Time to send message: 293.5522
Dec-22 7:57:42 AM Insteon ..Got RF PLM Response 02 62 45 CF 3E 0F 19 01 06
Dec-22 7:57:42 AM Insteon Received STX 0x50 (Raw Insteon Rec):45 CF 3E 13 00 04 C7 06 00
Dec-22 7:57:42 AM Insteon Saved ini file. msecs=70
Dec-22 7:57:42 AM Insteon ..waiting 252ms
Dec-22 7:57:42 AM Insteon Sending command 02 62 45 CF 3E 0F 19 01 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Dec-22 7:57:42 AM Insteon Setting status and value for device 45.CF.3E:4. Old status:100 Old Value:100, New Status:3 New Value:0
Dec-22 7:57:42 AM Insteon Setting status and value for device 45.CF.3E:4. Old status:0 Old Value:0, New Status:2 New Value:100
Dec-22 7:57:42 AM Insteon Setting status and value for device 45.CF.3E:1. Old status:0 Old Value:0, New Status:3 New Value:0
Dec-22 7:57:42 AM Insteon ProcessGroupBroadcast: Device Sensors Door Basement Door (45.CF.3E) sent heartbeat with cmd 13
Dec-22 7:57:42 AM Insteon Received STX 0x50 (Raw Insteon Rec):45 CF 3E 00 01 04 CB 13 04
Dec-22 7:57:42 AM Insteon Received STX 0x50 (Raw Insteon Rec):45 CF 3E 00 00 04 CB 13 04 Debouncing repeat.
Dec-22 7:57:41 AM Insteon Setting status and value for device 45.CF.3E:4. Old status:100 Old Value:100, New Status:3 New Value:0
Dec-22 7:57:41 AM Insteon Setting status and value for device 45.CF.3E:4. Old status:0 Old Value:0, New Status:2 New Value:100
Dec-22 7:57:41 AM Insteon Setting status and value for device 45.CF.3E:1. Old status:0 Old Value:0, New Status:3 New Value:0
Dec-22 7:57:41 AM Insteon ProcessGroupBroadcast: Device Sensors Door Basement Door (45.CF.3E) sent heartbeat with cmd 13
Dec-22 7:57:41 AM Insteon Received STX 0x50 (Raw Insteon Rec):45 CF 3E 00 00 04 CB 13 04
Lee,
what version are tyou running? if not the latest beta, please update and retest.Mark
HS3 Pro 4.2.19.5
