Hi Mark,
I have not been able to get the Tap-Add feature for Insteon devices in your HS3 plug-in. I used this feature in the HS2 Insteon plug-in successfully for many years. The interface currently used with Insteon is the Power Line Modem #2412S. This is what I tried:
1. First used version 3.0.5.10, then upgraded to 3.0.5.86; not working with either
2. Disabled and re-enabled the Insteon plug-in; status OK upon re-enabling each time
3. Rebooted computer a few times; no luck
4. Tried linking a few switches that I was trying to tap-add and could successfully link them both directions. (they seem to be communicating)
5. I took off wall plates, wrote down addresses, and tried adding the devices manually; no luck. The page indicates:
The plug-in is currently working. This page will refresh regularly and update the status. Do not leave this page until the 'Continue' button is presented.
Afterwards:
The Insteon device at 09.74.90 did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
*** I tried this on three devices in separate areas of the house that could directly link successfully to each other outside of Homeseer.
Note that I can still use HS3 to interface with previously addressed Insteon switches. Please let me know if you can help me further troubleshoot this issue.
Mike
HomeSeer Version: HS3 Standard Edition 3.0.0.293 (Windows)
HomeSeer: Is Registered
Operating System: Microsoft Windows 10 Home - Work Station
OS Version: 10.0.10586 Service Pack: 0.0
Insteon Error Report Attached
Afterwards:
Mike
